4000RPM Stumble
Yes I have these...
2001 996TT 3.6L and stock ECU
mine did not.
I think its the maf when those lights go on, the plugs generally throw a CEL light then the " Drive to garage " and when normal driving it goes away.....sometimes plugs don't even throw codes or a light..so It seems. I am going thru my own issue right now with sputtering, mine may be due to a recent DV upgrade.
idles perfect. boost is perfect and car pulls really hard till 4k where it just studders really hard. once it hits 5k it seems to pull hard again... only way around this ive seen is to shift to a lower gear pushing more than 5k and pull from there. every other gear never goes by 4k so it never studders again.
EXACT same problem I am having....only difference is I haven't seen the ABS or PSM light. I think our problems are 1 of 3 things
1) Plugs
2) MAF
3) Vacuum leak ( I think this may be my problem due to a DV issue )
I am going to get the car's codes read, even tho my brokway is seeing any there may be some)
1) Plugs
2) MAF
well mine is just limited to do.. the DV's have been installed a long time ago and have never given me any issue. :P
i think i might go with the MAF first since the ABS and PSM lights point me towards the MAF more than the plugs.
