4000RPM Stumble
4000RPM Stumble
so just got the ECU/exhaust/turbo/wastegate/spark plugs done and when i go WOT it stumbles around 4000RPM. eventually it goes away but its still annoying...
also, when i dont go WOT but go 3/4 of the way, it doesn't do this...
is this my maf going bad again or the programming.
plugs....
.. and hopefully not Apsolute...
markski
markski
2001 996TT 3.6L and stock ECU
Doesnt matter.
change them again- get one colder range... u probably messed one up with the extra boost..
Plugs...I had the same issue tonight, no warning they just die.Did you just do them as you did your upgrade? Also
are you seeing the CEL?
www.sparkplugs.com
8 - Denso Double platinum
Stock Number: 3245
Part Number: PK20PR-P8
Unit Price: $7.16
