PSA for those doing their own turbo / fpr install
Old Mar 17, 2008 | 07:15 PM
Tboy911's Avatar
Tboy911 is infamous around these parts
Me and a friend of mine both are doing the epl k16/16g kit at the same time.
I was putting in new plugs and changing to the 5 bar fpr on both cars while everything was apart, but was dreading taking apart everything up top and beating up my hands for the 5 bar.
If you remove the coil pack closest to the front of the car on the passenger side the fpr is pretty easily accessible from the bottom. I was able to use long needle nose pliers to pull the clip out and could get my hand in there to wiggle it out. went back in pretty easily the same way. Took 5 minutes.
Old Mar 17, 2008 | 07:31 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Thanks for that tip, I am sure other members could use that info.
Old Mar 17, 2008 | 07:40 PM
If you remove the front most coil pack on the driver side the fpr is pretty easily accessible from the bottom. I was able to use long needle nose pliers to pull the clip out and could get my hand in there to wiggle it out. went back in pretty easily the same way. Took 5 minutes.
You mean cylinder #6 coil pack on the passenger side... which the one closest to the front of the car.... but on the drivers side- not passenger side.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 17, 2008 | 07:50 PM
Tboy911's Avatar
Oops fixed it. Closest to the front of the car passenger side.
Old Mar 17, 2008 | 07:52 PM
kilrgt's Avatar
thats markski knows all.
Old Mar 17, 2008 | 07:54 PM
LOL I just changed mine in the past a few times so I remembered lol
9.66
click to view
Mackchacha
Jul 9, 2019 11:03 AM
MadWhip
Sep 3, 2015 02:04 PM
TrackOne
Aug 20, 2015 12:56 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
