Oil return line question?
Old Mar 19, 2008 | 08:29 PM
antoniosz32's Avatar
antoniosz32 is a name known to allantoniosz32 is a name known to allantoniosz32 is a name known to allantoniosz32 is a name known to allantoniosz32 is a name known to allantoniosz32 is a name known to all
I have noticed a lot of the upgraded turbos are garrets, what are those oil boxes coming off the turbo? Why not just a simple gt oil drain return?
Old Mar 19, 2008 | 10:19 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
The factory design uses an oil sump/scavenger setup and the aftermarket turbos must retain it or use a similar design. The simple oil drain return you have seen on other cars relies on gravity, but that will not work on the Porsche because the turbo oil outlets are lower than the engine.
Old Mar 20, 2008 | 07:27 AM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
any pics of that? have to use a pump per turbo?
Old Mar 20, 2008 | 08:31 AM
Ohh I see, these cars aren't dry sumped from the factory like the vettes are are they? So the second line coming into the oil box helps drain the oil? Do companies sell those oil boxes alone or do you have to buy their kits?
Old Mar 20, 2008 | 07:37 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
On KKK or KKK/Garrett turbos, you can use the OEM oil box and lines. If you decide to go with a regular Garrett or similar turbo, you won't be able to use the OEM oil box. Some companies who use the regular Garrett turbos have designed their own oil boxes though.
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
Lucid Moment
Aug 20, 2015 02:22 PM
