Need help with Shift Knob / Short Shift
Old Jul 4, 2004 | 12:16 AM
dmilzoff's Avatar
dmilzoff is infamous around these parts
Need help with Shift **** / Short Shift
I'm installing the B& M Short Shift and all is going well BUT I can't get the leather shift/shift **** off of the old shifter. Is there a set screw or something hidden which I don't see? Someone help me finish this so I can drive the car!!
Old Jul 4, 2004 | 12:24 AM
dpblessing's Avatar
senior member
dpblessing is infamous around these parts
If you have the alu look shifetr, yes there is a set screw at the 12 o-clock position under the leather.
If you have the standard non-alu unit, then it should just pull up / off
Old Jul 4, 2004 | 12:27 AM
Dr. T's Avatar
Dr. T is infamous around these parts
Pull the trim ring with the leather boot all the way up. There is a 5mm hex set screw in the front holding the **** on.
Old Jul 4, 2004 | 12:28 AM
Tool Pants's Avatar
Tool Pants is infamous around these parts
The base shift **** is just a friction fit. Some of them take some effort to pull off. If that is what you have then grab the **** and twist it back and forth to slightly expand the plastic sleeve the holds in on the metal lever. Then pull.
This is the optional **** with a set screw.
Old Jul 4, 2004 | 12:59 AM
dmilzoff's Avatar
You guys are great. I love you - I mean I like you alot. ToolPants, thanks for the pictures.
The Short Shifter and Shift Link are in. The short drive I took revealed that the shifter is just what I wanted!!
smartbot
Jul 18, 2016 01:15 AM
PelicanParts.com
928
Oct 7, 2015 02:01 PM
PelicanParts.com
924/944/951/968
Oct 7, 2015 02:00 PM
sparks
Sep 8, 2015 03:03 PM
997zen
Sep 7, 2015 07:13 AM
