More MAF fun
Old Mar 20, 2008 | 03:17 PM
wstsdphisg's Avatar
wstsdphisg is infamous around these parts
More MAF fun
Hey Guys,
I got the dreaded MAF Trio (PSM, ABS and Check Engine) indicators all going off at the same time. I took it into the dealer they said bad MAF.
I did some research on bad MAFs and saw how easy it is to do-it-yourself. So I took a shot at it. Bought the Torx screwdrivers including T-20 got my can of electrostatic non-residue cleaner etc. but now I ran into a problem and need some advice.
When I tried to use the T-20 to unscrew the screws on each side of the MAF it was too big, it won't fit in the groove. (Is there a problem here? It seems like the T-20 is the right size for everyone else)
I tried the next size down (T-15) and its too small. Just for fun I tried a hex key where I did find one that fit, but the diameter is so small I think I'm going to bend the key before I can loosen the screw.
Anyone have any ideas? Am I doing something wrong? There is a bit of rust I think on the head of the screw/bolt. Do I need to go find a T-18?
Also one more thing its weird when you look at the screw it looks like a hex pattern (Hexagon) not a Torx (star). I've got the vflow from evo. Anyone else notice the same thing?
Best,
Jake
Old Mar 20, 2008 | 06:48 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
Yes, you need a security torx bit.
Since you said you have a vflow, EVOMS includes a security torx bit in the box when they ship it, so I would check to see if it is still in the box.
If you can't find it, Sears usually carries the security bits.
Old Mar 20, 2008 | 10:35 PM
ard's Avatar
ard
On other cars I just grab the screw head with a pliers... or dremel a slot into it!
Heck, you can replace the screw with a nice new one later if you want...
A
Old Mar 21, 2008 | 07:05 PM
wstsdphisg's Avatar
After a two more trips to home depot it turns out when they installed my Vflow they must have changed the screws from Torx to standard hex pattern screw. I ended up picking up a set of hex bits and it did the trick. Thanks for everyones input.
Old Mar 21, 2008 | 07:47 PM
dtmarsh's Avatar
dtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud of
I have a VFlow and I got the same thing today, PSM, ABS and check engine light coming up Hwy 1 into Monterey. Went straight to the dealer and they replaced the MAF. The MAF cost me $630. But I did learn how to install it. Sheesh. Is there a place to buy these things for less than $600? Also, how often should the filter in the VFlow be replaced/cleaned?
Old Mar 21, 2008 | 08:29 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
get for less at neillo porsche plus a 10 % discount if you are a pca menber...
Old Mar 21, 2008 | 08:30 PM
opps they are in rocklin ca ... east of sacramento ca
Old Mar 22, 2008 | 01:50 PM
wstsdphisg's Avatar
I bought a new MAF online for about $250 off ebay. Waiting for delivery, I'll let you know if everything works out. I agree though I need directions on how to pull the vflow filter off and clean it. I assume its just a loosening of the clamp and pulling it off, but when I looked at the spacing it seemed pretty tight. I'm guessing you can clean it like the B&M filter with just soap and water. Any one clean their vflow?
Old Mar 22, 2008 | 10:29 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
Holy mother of god!! I didnt know that it MAFs cost that much ... I was under the impression that it was in the $200 - 300 range ...
Which dealer took your money?
Old Mar 23, 2008 | 12:27 AM
Zippy's Avatar
Your need a new dealer.
Old Mar 23, 2008 | 08:10 AM
wross996TT's Avatar
I've heard of bending over backwards, but you bent over forwards...lose the V-flow if you want to stop blowing MAFs.
Old Mar 23, 2008 | 04:30 PM
dtmarsh's Avatar
Actually it was $630.00. Monterey, CA
Old Jun 17, 2008 | 07:42 PM
judgejon's Avatar
judgejon has a spectacular aura aboutjudgejon has a spectacular aura about
when you changed/cleaned the MAF did you disconnect the battery?
Old Jun 17, 2008 | 08:21 PM
ard's Avatar
ard
I've disconnected many MAFs, changed them, cleaned them...never disconnected the battery. Just disconnected and reconnedcted on the turbo and no problems. With the engine off, the DME is not powering the MAFs so no worries.
Old Jun 17, 2008 | 08:30 PM
Staff@RPM's Avatar
Staff@RPM is infamous around these parts
Hi... Sent you a PM.....Tim
