Ever Broken a Sway Bar Link? Time to Beef Up!
Old Mar 26, 2008 | 04:30 PM
vividracing's Avatar
Agency Power has just released their new front adjustable sway bar links for the Porsche 996TT and C4. Check out the info here - http://www.vividracing.com/catalog/agency-power-front-adj-sway-bar-links-porsche-996ttc4-0105-p-47974.html
Only $299 per set - I am giving 6speeders lifetime warranty on these.
Agency Power has released these adjustable front sway bar links for the Porsche 996 Turbo and C4 models. The sway bar link features a CNC machined aluminum turn buckle that has a slight bend for clearance purposes. The piece is anodized in blue and then laser engraved with the AP logo. The precision machined part features spherical rod ends on either side with opposite threads for on the fly adjustments. The 3 piece Teflon lined rod ends include CNC machined steel spacers which fit the 10mm and 12mm steal bolts. Both of these pieces are done in a black oxide finish to protect themselves from the weather elements.
Unlike the factory part which is long and mounts near the bottom spring perch, these shorter, beefier sway bar links mount from the sway bar then connecting to the hub carrier where the shock slides through. These sway bar links fit with most aftermarket sway bars and coilover setups. They are sold as a pair and include everything needed for installation.
Jul 29, 2019 11:13 AM
r_matt_6
Oct 8, 2015 06:07 PM
TrackOne
Aug 20, 2015 12:56 PM
