anybody know how to use this to check wastegate
Old Mar 27, 2008 | 03:03 PM
melsta's Avatar
melsta has a spectacular aura aboutmelsta has a spectacular aura aboutmelsta has a spectacular aura about
hey guys i just order this from fvd http://fvd.de/us/en/Porsche-0/996_TT...um-tester.html but i have no clue how to use it. i am trying to find out if both of the wastegate springs are set to open at the same psi? am i suppose to get a tool that pressure the wastegate instead of vacuum?
thanks in advance guys
Old Mar 27, 2008 | 09:38 PM
melsta's Avatar
nobody knows?...................
Old Mar 27, 2008 | 09:45 PM
triple_nickel's Avatar
triple_nickel is infamous around these parts
It's just a simple hand vacuum/positive pressure pump. Hook the hose to the end of the tool and then to the wastegate. Pump the tool and watch the vacuum/pressure gauge. Stop when the wastegate opens and read the gauge. Check out this site for some info from Mityvac, a manufacturer of vac. pumps.
http://www.mityvac.com/pages/tech_info.asp
Edit: The top port produces pressure where as the front port produces negative pressure (vacuum)
Old Mar 28, 2008 | 12:10 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
I used a pressure cooker gauge on my vacuum pump to calibrate mine
http://www.totalvac.com/parts/PR-853...&zmap=PR-85374
hope this helps
Old Mar 28, 2008 | 01:49 AM
Turbo Fanatic's Avatar
I believe on a K24 car you want the wastegates to start opening at 12 psi. That will get you 1.2 BAR. Not sure on a K16 car.
DB-Design-Group
Group Buys
46
Nov 3, 2015 11:27 AM
jaehoppa
Oct 22, 2015 09:17 PM
Jeanmarcboilard
Sep 22, 2015 05:03 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
ship it
Sep 7, 2015 10:49 AM
