Dyno results on X50 with FVD flash
Old Apr 6, 2008 | 08:39 AM
Dirty Mac's Avatar
Dirty Mac is infamous around these parts
Originally Posted by STEVE KOJASEVIC
isnt that kind of low ?
i thought chipped k24 cars made 500 at the wheel ?
That would work out to 600hp at the crank assuming 20% drivetrain loss. Since the base X50 is 440 @ crank, I'm pretty okay with my results (about 510hp @ crank). And that is exactly what FVD's web site promised (although my torque is a lot lower than their estimates).
Old Apr 6, 2008 | 08:44 AM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
I didn't want to rain on your parade, but that's what I was thinking. The torque seems rather low, although the curve is very flat. Was this on 93 octane?
Old Apr 6, 2008 | 08:50 AM
Dirty Mac's Avatar
Ya. There was a post a while back with someone at FVD claiming there is no gain with higher octane. On FVD's web site, their torque curve is very peaky.
Old Apr 6, 2008 | 11:44 AM
Turbo Fanatic's Avatar
Sounds like you are going to get the upgraded wastegates. you won't need to dyno it afterwards. You'll just know you've reclaimed the missing torque/HP.
I have a similar setup with GIAC. My dyno run was RWD on a Dynojet (which are known to read higher) running 91 octane, 80 degree day, max boost 1.1 BAR (I have since tightened the wastegates an run a solid 1.2). Almost every parameter was different!
Old Apr 6, 2008 | 11:56 AM
Dirty Mac's Avatar
Maybe I won't need to ... but I will
Old Apr 6, 2008 | 12:47 PM
Great! We need empirical conformation.
Old Apr 6, 2008 | 07:29 PM
oak's Avatar
oak
I think you may have problems with upgraded wg with the fvd programming. fvd has an agressive 1.1-1.2 program that doesn't need upgraded wgs the extra boost is programmed.
Old Apr 6, 2008 | 07:56 PM
Dirty Mac's Avatar
Ohhh. What a twist!!!! Just when it seemed so simple.
Old Apr 6, 2008 | 08:18 PM
OCTurbo's Avatar
OCTurbo is infamous around these parts
i also think those dyno numbers look very low. I have seen dyno's of stage 2 cars (k16's with chip and exhaust) putting down about the same hp to the wheels. A stage 2 car should be between 500-510 at the crank, so i think you should be at least at 550 at the crank.
Old Apr 6, 2008 | 08:58 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Oak,
I ran the upgraded wastegates with K16/24 turbos and FVD Stage 4 software (1.2 bar program) and did not have any problems at all - the car ran perfectly. Whether I really needed the wategates or not, I'm not sure, but Speed Gallery put together the kit and recommended them, so I took their advice and I was very pleased with the final product. No wastegate problems.
Old Apr 6, 2008 | 09:44 PM
oak's Avatar
oak
john, fvd has some aggressive prog that aren't well known and offered to general public. there are some programs that have issues with ob and will go into limp mode. I'm sure if sg put a kit together it's done well.
Old Apr 7, 2008 | 08:59 AM
Fabspeed Motorsport's Avatar
Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !
Here is a dyno graph of a 2004 X50 that we did a while back on our 4wd Dynojet. Car had Fabspeed version 3 exhaust, fabspeed headers, BMC filter, and PES ECU software. These numbers are at the rear wheels, because the customer has the driveshaft removed from the car.
Old Apr 7, 2008 | 09:42 AM
Dirty Mac's Avatar
YIKES! I don't even know what to say. That's a huge difference. Do you have a stock baseline for the car? If not that one, do you have any stock X50 graphs? Is it possible that Dynojet tries to simulate crank hp on its output? Cause his hp number is very close to my estimated crank numbers. Although his graph shows my torque curve is definitely lacking.
Old Apr 7, 2008 | 09:45 AM
Dynojet on RWD vs. Mustang on AWD = apples to oranges.
However, either way, peak torque should definitely exceed peak hp.
Old Apr 7, 2008 | 10:18 AM
I did not post the graph to compare a dynojet to a mustang Just trying to throw out what kind of numbers we saw on our dyno which are similar to the numbers ari put down with his car on a dynojet
These numbers are to the wheels, and are not corrected numbers to the crank!
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
gadgetman
Sep 10, 2015 03:29 PM
gadgetman
Sep 10, 2015 11:33 AM
shifter_
Sep 2, 2015 03:33 PM
