Another M3 vs GT660 vid
Old Apr 13, 2008 | 05:52 PM
Divexxtreme's Avatar
Originally Posted by HPF Chris
The M3 is running a stock engine (at 11.5:1 compression ratio). On pump gas without methanol the M3 only makes 425rwhp. With pump and methanol it makes approximately 550rwhp. With race fuel it makes 600rwhp and with race fuel and methanol it makes 625rwhp.
Chris.
Very nice, Chris. Congrats. Your cars are running very strong.
Old Apr 16, 2008 | 08:37 PM
ChrisNW's Avatar
ChrisNW has much to be proud ofChrisNW has much to be proud ofChrisNW has much to be proud ofChrisNW has much to be proud ofChrisNW has much to be proud ofChrisNW has much to be proud ofChrisNW has much to be proud ofChrisNW has much to be proud of
Scott,
Thanks.
I heard your Porsche is an ANIMAL! Your car gives us something to shoot for.
We only have 2 boost target settings. One is used for 91 octane pump, and the other is used for pump+meth, race and race+meth. This unfortunately makes our pump+meth boost level the same as the race fuel level which only allowed us to run 23psi for high boost.
With stage 4 we're going to cut that back to 3 settings so we can target a much higher boost level. It will be pump, race and race+meth. We just need to run a slightly larger turbo and a different clutch and I think we can squeeze 1,000rwhp out of it.
I should have some Stg4 results in another month or so. Talk to you soon.
Chris.
Old Apr 16, 2008 | 09:10 PM
Scott,
Thanks.
Chris.
23 psi is my max boost level as well. I don't run meth, though. Just race fuel.
Looking forward to seeing your Stage 4 results.
Old Apr 17, 2008 | 11:15 PM
ChrisNW's Avatar
Yea, I think we're going to need stage 4 to keep up with you.
Old Apr 17, 2008 | 11:42 PM
iLLM3's Avatar
My goodness, I seriously want another M with this kit hmmm
Old Apr 18, 2008 | 06:23 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
how does the rest of the driveline hold up? This is exceptionally impressive
Old Apr 18, 2008 | 08:48 AM
ChrisNW's Avatar
Thanks. The entire drivetrain has held up without incident so far. The factory drivetrain is pretty stout, but I also believe one of the main reasons is that we're still retaining the factory dual mass flywheel, and we're running a slippable single disk clutch. This provides a nice cushion every time the car is shifted. We also have yet to someone take these beasts to the track with some monster slicks and do a major launch. At that point we'll know if there are any drivetrain components we need to create.
Chris.
Old Apr 18, 2008 | 12:06 PM
ChrisNW's Avatar
Did you make 889rwhp at only 23psi, or was that done at higher boost? In the Supra's we're lucky to make 700rwhp at 23psi so I was surprised to make around 819rwhp at 23psi in the M3. To make 889rwhp at 23psi in the M3 would require a larger turbo than the 74GTS we're running.
If you wouldn't mind me asking, what engine displacement and turbo are you running?
Chris.
VID997
97
Mar 20, 2018 02:23 PM
captain Greg
Sep 23, 2015 08:19 PM
longboarder
Sep 12, 2015 12:55 AM
ss2z06
Sep 9, 2015 11:46 AM
