New PS2s ... and tire pressures
Originally posted by dmilzoff
Damon
I've been taught to have a 'target pressure' for the tires you are using For me, with MPCs in stock size, it is 36F/32R. When I track the car, I start with that pressure and after each 20 minute run, I reduce pressures to 'target pressure' and go out again. After two and three runs I find that the need to reduce pressures less.
Is this a proper way to set pressures?
Damon
On most cars, start with inflation pressures between 35 and 40 psi ("cold" inflation pressures for autocross use and "hot" inflation pressures for racing use). Cars that are light, well-balanced and relatively easy on tires will find slightly lower pressures may work for them, while heavy, high horsepower cars that are generally harder on tires may find that they need slightly higher inflation pressures.
Generally adding air pressure in small increments (2 psi) to the tires on the end of the car that loses traction first works best. For example, if a car is understeering, add pressure to the front tires. If the car is oversteering, add pressure to the rear tires.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
L.A.P.
Oct 19, 2015 10:01 PM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
L.A.P.
Aug 23, 2015 11:48 PM
