Camber issues on rear?
Old Apr 22, 2008 | 01:48 PM
SweeeTT's Avatar
SweeeTT is infamous around these parts
I have a 996tt, and I am going to put 997tt 19 inch wheels and tires on it, with 305 Bridgestones on the rear. Stock suspension. The problem - the rear tires, especially the driver's side, rub HARD against the fender liner! I have tried 7mm spacers, and to experiment, I even tried two of the spacers (total 14mm) on the driver's side (I didn't drive it that way, I just installed them and lowered the car off the jack to see if they would clear). Still rubbing slightly on the lower part of the rear inner fender.
If I spaced it out any more, I can see clearly that the outer side top of the tire would hit the fender lip, so it seems as if there must be little or no camber built into my alignment set up. There are no handling issues with my stock 18 inch rims and 295 p-Zeros on the rears, no rubbing, and there is no evidence of accident damage (paint is original, carfax clear, nothing bent on the suspension)
Has anyone else encountered this? Is there enough adjustment built into the alignment that the previous owner could have had the camber adjusted to almost vertical?
Old Apr 22, 2008 | 09:24 PM
triple_nickel's Avatar
triple_nickel is infamous around these parts
Yup, they'll rub depending on the tire aspect ratio. I've run 305/35R-18 RA1s (26.3 in dia./12.5 in width) on the rear with about -1.5 camber and they rub the liner toward the rear near the IC hose.
Old Apr 23, 2008 | 12:00 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
The offset is different for a 997tt than a 996tt but your spacers should have compensated for that. I agree with Triple, the problem is in the aspect ratio. The stock tires are 295X30x18 which yield a tire height of 24.97". The Bridgestones are 305x30x19 which have a tire height of 26.2". Your tires are about .60 taller inside the wheel well. For more than just clearance reasons (ie the all wheel drive system) you should keep your tire height within 2% of the OEM spec and within 2% front to rear. I installed PPS10 that lowered my 996tt 1.5" front and 1" rear using F235x30x19 et43 and R315x25x19 et39. I had to roll the inside fender lips of the rear to make sure they did not rub. Camber is set a -1.5. I think you'll have to go with different tires and spacers to stop the rubbing.
gulf gt
Aug 27, 2015 10:27 AM
I'mAllIn
Aug 25, 2015 09:44 AM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
TrackOne
Aug 20, 2015 12:56 PM
