Tire Advice Needed
Old May 8, 2008 | 01:25 PM
quicksilver01's Avatar
quicksilver01 is infamous around these parts
Tire Advice Needed
I'd like to replace the stock Pirellis ( 225/40/18 & 295/30/18 ) on my 2001 996 TT with MPS2s.
Tire Rack suggested 235's & 315's. My car has an X73 suspension. Will they fit my stock rims? Will they rub due to my lower suspension? Any advice would be greatly appreciated.
Old May 8, 2008 | 01:42 PM
triple_nickel's Avatar
triple_nickel is infamous around these parts
235/40R-18 and 315/30R-18 - no problem assuming 18x8.5 front and 18x11 rear with the right offsets (stock offset) and reasonable lowered ride height. I run NT01s in this size on stock turbo twist wheels.
Old May 8, 2008 | 03:44 PM
Mikelly's Avatar
I just bought the MPS RIBS for my car, swapping out the Pirellis I had... I can't comment enough on the difference just in lack of road noise. I was amazed at how quiet this car is now... I stuck with the stock 295/35 rear 225/40 front 18inch sizes.
Road manners are much better as well...
Mike
Old May 8, 2008 | 08:02 PM
Vyper340's Avatar
Vyper340 has a spectacular aura aboutVyper340 has a spectacular aura aboutVyper340 has a spectacular aura about
MPS are a must!! There should be no issues with fit
Old May 8, 2008 | 08:44 PM
TonyTurbo's Avatar
TonyTurbo is infamous around these parts
Tires
The 235/40 No Problem w/stock rims, had them on my car, but for the rear I used the 295/30, but I think the 315 will work. Tony hope this helps a little.
Old May 8, 2008 | 09:02 PM
Prche951's Avatar
I have heard that you want to keep the diameter of both front and back nearly the same and if you go 235 in front you need to go with 315 in back if they will fit in order for the diameters to match. This is not my experience just what I have heard.
Old May 9, 2008 | 02:33 PM
Mikelly's Avatar
That is absolutely not true... The 235s will work with 295s, 305s or 315s depending on the exact diameter of each tire... You have to do the math and come up with "within" 3% of the same diameter front to rear.
I run 235 front MPSCs and 295 rear MPSCs at the track with zero issues.
Mike
Old May 9, 2008 | 05:03 PM
Prche951's Avatar
Mike
Cool, so you can run the 235 mich up front with the 295 mich in back since the front is 25.4 and the back is 26.1 and that is 3%.
Will a 245 fit on a stock rim with stock spacing without rubbing in front. I hear of guys running 265's and 255's, but I am not sure if they have modded their cars.
also will 315's fit on stock rims in back with no mods?
Old May 9, 2008 | 07:35 PM
tom kerr's Avatar
I run 265 335's with no problem for you guys that dont believe mike
Old May 9, 2008 | 09:11 PM
Prche951's Avatar
you running those tires with stock wheels and no camber or rolled fender? That would be impressive.
I keep on hearing different stories. Some people have rubbing issues others dont.
Old May 9, 2008 | 09:17 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
The rear of a TT needs all the help it can get. I've got 315x25x19 on the rear lowered about an 1". I rolled the lips...no rubbing. Rolling the lips is no big deal.
Old May 9, 2008 | 10:49 PM
av2's Avatar
av2
av2 is infamous around these parts
To retain stock feel, I would keep it the same size. The tires will come out a little bit.
Old May 10, 2008 | 04:18 AM
Mikelly's Avatar
Tom has roled fenders and most likely camber plates... I didn't run the 245 on mine and didn't do the math, so you'll want to do that, but the bottom line is there can only be up to 3% difference in tire diameter. Beyond that, it's up to you... I chose not to run the 315s I had, as they rubbed the inner fender close to the boost hose, and that was that... I've never had problems with the 295s and my car is making more power than a lot on this board... Others here can attest to how my car handles when it's out on course lapping..
Mike
Old May 10, 2008 | 07:34 AM
Prche951's Avatar
Mike, thanks. Makes sense, the fact that you are running slightly larger in front probably helps point the front end better and adds a little weight up there. I was only thinking of 315's because I found a really good deal on a set, but I'll probably stick with 295's back there and go up to 235's in front or maybe even 245's if they will work. Doesn't seem like much of a difference, but I certainly do not want to have rubbing issues. Probably stick with 235's in front. Oh and Mike, a little birdie told me about your car, sounds like a beast, did you get one of Kevins tranny deals. I wish I had money right now.
Duanne, if you hadn't of lowered the rear or rolled the lips, wold those tires rub?
Old May 10, 2008 | 07:43 AM
Mikelly's Avatar
I haven't jumped on Kevin's tranny deal yet, because I've been toying with selling mine, but would consider it later in the spring/summer once I recoup from the last 6 months of upgrades... Putting the added width of tire up front helps me make the front stick better on turn in and allows for a bit better balance with my personal setup. I'm only running 1.5 negative camber up front and 2.0 in the rear, with the sways set on the middle setting, with PSS9s set at 1 on the back and 3 up front! So for me, that seems to work pretty darned well.
Mike
Jul 29, 2019 11:13 AM
Zero911
Aug 24, 2015 06:51 PM
00aston
Aug 24, 2015 09:29 AM
Fadi
Aug 21, 2015 03:43 AM
