HELP!! My car is stalling!!
Old May 10, 2008 | 01:47 PM
pgcanillas's Avatar
pgcanillas is infamous around these parts
I need help! My car is stalling when I decide to run trough the gears quick. If I, as an example, use 2nd gear to redline, when I shift to 3rd the car run poorly (stalling), but if I lift the gas pedal for a second, and push it again, the car runs as it should. It has this problem when I shift quick and near redline. On the other hand boost is OK at 0,7.
So what do you think?
PD Excuse my English!!
Old May 10, 2008 | 07:26 PM
wross996TT's Avatar
get your codes read...durametric, PST2 or PIWIS....
Old May 10, 2008 | 09:26 PM
ckm88's Avatar
ckm88 is infamous around these parts
Sounds like you're running extra rich at high end rpms to safeguard your engine from running lean and blowing up. I think when you say "stall" you might mean bog. If the car bogs at higher rpms, then it is most likely to a poor a/f ratio up top or a hose leak. Definitely go to a mechanic and get it checked out. Hope that helped.
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 09:56 AM
