GIAC Race File
Old May 11, 2008 | 11:25 AM
Turbo Fanatic's Avatar
GIAC Race File
Do you guys recommend getting this?
Is there a noticeable difference? What's the HP increase over the normal 91 octane K24 file?
Old May 11, 2008 | 11:59 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
When I had it on my TT I did not notice any difference.Plus GIAC made me purchase the race file w/ the stock file. I could not just purchase the race file. Proto from now on.
Old May 11, 2008 | 12:30 PM
I already have the 91 octane and stock. It would cost something like $250..
Old May 11, 2008 | 01:31 PM
Ask to try it for a couple of days and see if you think its worth it.
Old May 11, 2008 | 07:17 PM
patman's Avatar
patman is infamous around these partspatman is infamous around these parts
Ari,
i'll recommend it because it felt more aggressive & boost came on quicker when i put race gas in after Sam/Dan @SG installed my race file. They said approx. 35hp gain on race. I've only dyno mine on 4wd mustang dyno not w/ race gas yet so don't know exact gain. My TT is my weekend car as of late so i usually use race gas. Worth the difference for our turbos IMO.
Old May 11, 2008 | 07:47 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
I would stick with what you got. If HP goes up to 100HP it would be worth it. Just my opinion though.
Old May 12, 2008 | 02:35 PM
patman's Avatar
Also Ari,
$250 probably costs less than a pair of your designer jeans. Shouldn't need to think about it for the additional 35hp+...We turbos are hp freaks man!!
Old May 12, 2008 | 03:22 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
How do you initiate the race file? or do you just add more octane and the computer adjusts?
Old May 12, 2008 | 03:48 PM
I wear lucky jeans I got from Costco. Under $40
Originally Posted by patman
Also Ari,
Old May 12, 2008 | 04:07 PM
patman's Avatar
just add the race gas & the ecu will auto. adjust timing.
you're kidding me! I used to rock Lucky Jeans back in the days so they're atleast 1.5 Benjis..
Old May 12, 2008 | 10:02 PM
The GIAC comes with a flash loader. Just plug it into the OBD port and select stock, 91 octane and race files. It takes about 20 seconds.
It was state of the art 3 years ago. Now everyone seems to have this ability.
Old May 12, 2008 | 11:03 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
for $250 its a great deal. I'm pretty sure thats the going rate....
SG wanted me to pay $1000 for the loader and race file for my SG700....
Old May 13, 2008 | 12:46 AM
art4iza's Avatar
They wanted the same from me, I just dropped a little more weight from the car. Not worth it from SG. But for $250 might be worth it.
Old May 13, 2008 | 12:54 AM
patman's Avatar
That much? What other local shops would you recommend? Post it here or pm me pls.
Old May 13, 2008 | 01:33 AM
drjoe's Avatar
drjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the rough
i think its worth it...it give you a 1 to 2 car length edge , with everything else being the same....
