Help- car not starting!
Old May 27, 2008 | 10:09 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
any thoughts as we flat bed it to the dealer....
engine will turn over but not fire up. no CELs and voltage seems ok
Sameer
Old May 27, 2008 | 10:15 AM
WOODTSTER's Avatar
weird...
another 6speeder is going thru this right now.
I hope SPEED GALLERY gets more helpful!!!
S-351's Speed Gallery GT2 has not run in a couple of weeks ????
New Tune, new injectors:
started for about 10 minutes; blew the intank corrugated fuel line (which has been replaced) and has not
restarted since ???
Very, very "weak" in my opinion!!!
MK
Old May 27, 2008 | 10:24 AM
CinqueValvole's Avatar
CinqueValvole is infamous around these parts
Had the same problem with my Audi. Does the CEL light come on when you switch on the car?
I swapped out the ECU and the car fired up. Turns out that either the chip or the solder was bad. Had the stock chip resoldered and it was fine. See if you can get the car reflashed.
Old May 27, 2008 | 11:10 AM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
I went thru this with one of my other P-cars, turned out it was a fuel pump.
pwdrhound
Sep 16, 2021 02:27 PM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
vr6tee
Aug 29, 2015 03:52 AM
gulf gt
Aug 27, 2015 10:27 AM
DSCOFF
Aug 23, 2015 01:22 PM
