proto tech in florida
Old Jun 6, 2008 | 08:54 AM
WOODTSTER's Avatar
Prototech GT2
This one is SERIOUS
Old Jun 6, 2008 | 12:51 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
Originally Posted by Adam Bowles
download your ECU via the provided OBD2 cable and software, and he will email you the software. You then install it via an OBD2 cable and your done. You do need a laptop computer though (unless you setup your PC in your garage).
What OBD2 cable and software are you referring to ??? Durametric?
Old Jun 6, 2008 | 06:57 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
You download the "Flash Client Software", which allows you to flash your vehicle via your laptop. After that software is downloaded, you plug the provided cable (similar to Durametric, with OBD2 on one end and USB on the other) into your computer and your car. Once that is done, you open the "Flash Client Software" icon, and copy your ECU. This copy is sent to Protomotive. You then unplug everything and your done...for now. Within 24 hours or so, you will receive an email with the new upgraded ECU file. You plug everything in, open the new file, and follow directions. Within 5 minutes, your car is flashed and you're haulin ***!!!
Simple as that!!
Old Jun 6, 2008 | 09:18 PM
thankful's Avatar
thankful is a glorious beacon of lightthankful is a glorious beacon of lightthankful is a glorious beacon of lightthankful is a glorious beacon of lightthankful is a glorious beacon of light
Love it.
FUTURESTAR
BMW //M
Nov 18, 2015 10:37 PM
C5tt
Oct 24, 2015 07:35 PM
freddiemac
Oct 7, 2015 11:05 AM
drkbrent
Oct 1, 2015 07:30 AM
gjpearce
Sep 30, 2015 04:26 AM
