B&M short shift help
Old Jul 23, 2004 | 08:05 PM
maxjamie's Avatar
Porsche Rocks
maxjamie is infamous around these parts
just installed in car B&M SSK , seems to shift into all gears but when I went for a test drive, I am having hard time getting it into reverse, it keeps on going into 1st. All the forward gears seems to engage fine. Which cable needs adjusting? and which direction? Anyone with this experience? Thanks for your input/advice. TC
Old Jul 23, 2004 | 08:30 PM
Porsche Tech's Avatar
Porsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nice
Check the plastic ball socket pieces- if you put the plastic cable ends in too far than that will affect the amount of travel on that affected cable. I always mark them with a dab of paint before removal but there is a small square-like mark on the ball socket that should closely relate to the rear end of the plastic cable end (threaded). Look at the left cable particularly. Seth
Old Jul 24, 2004 | 01:51 AM
maxjamie's Avatar
Porsche Rocks
When I did the install, I made sure of counting the threads and marking with a piece of tape on the rear cable part. You suggest that I adjust by pulling back on the left cable to show less threads on the cable housing? TC
Old Jul 24, 2004 | 06:27 AM
maxjamie's Avatar
Porsche Rocks
Got it!!! I took out the console and just looking over the cables and found out the cables were not seated in the housing properly. It's now working beautifully!!. Love the knotchy short throws! TC
carbonjim996TT
Sep 20, 2015 08:14 AM
BLKMGK
Sep 19, 2015 03:51 PM
sparks
Sep 8, 2015 03:03 PM
997zen
Sep 7, 2015 07:13 AM
