fuel pressure regulator install
Old Jun 13, 2008 | 06:21 AM
BUFFALOTT's Avatar
BUFFALOTT is infamous around these parts
installed a 5 bar regulator but when reinstalling could not find vaccum line for the regulator but i found a black plastic tube next to the regulator, i am assuming that the rubber hose that connects the regulator to the tubing came off. dose this sound like the right vaccum line? could not find any other lines.
Old Jun 13, 2008 | 07:05 AM
Evader's Avatar
Evader is infamous around these parts
The vacume line for the fuel pressure regulator is a little black hose that has a 90 degree turn on the end. If you removed the vacume pump to replace the FPR then you would notice that the vacume line for the FPR turns 90deg out from it and then heads down towards the drivers side of the car underneath the intake manifold. Obviously the vacume line should be installed on the nipple end of the FPR.
Hope that helps................
Old Jun 13, 2008 | 07:12 AM
BUFFALOTT's Avatar
fuel regulator
replaced the regulator from the bottom while changing out turbos and plugs not the best view, i think the rubber 90 came offwhen removing from the old regulator could not find it.
Old Jun 13, 2008 | 07:32 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
That's it.
Old Jun 13, 2008 | 08:26 AM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Originally Posted by $manager
That's it.
Yeah
Jul 29, 2019 11:13 AM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
tkebp1275
Aug 31, 2015 06:35 PM
The Oss
Aug 24, 2015 08:19 PM
Weebs
Aug 21, 2015 06:35 PM
