Ipod conversion on 01 996 Turbo?
Old Jun 13, 2008 | 08:36 PM
vv23's Avatar
vv23 has a spectacular aura aboutvv23 has a spectacular aura about
OK so i've searched, and can't seem to figure out if i'll be able to add an ipod ICELINK or something to my 01 996 Turbo. Mine has the factory navigation. Is there an ipod adapter available for it? Is it controllable from the factory deck?
any other way to have a music harddrive system controllable from the factory deck?
Thanks.
Old Jun 13, 2008 | 08:51 PM
imolafem's Avatar
imolafem is a jewel in the roughimolafem is a jewel in the roughimolafem is a jewel in the roughimolafem is a jewel in the rough
Very interested in this as I'm in the same boat and want to use my iPod in my Porsche...
Old Jun 14, 2008 | 12:08 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
I did a gateway 500 but it was on a 03 MOST optic loop nav unit. Check out Bumper Plugs. They would know if it would work on a 01
Old Jun 14, 2008 | 12:20 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
I've got an 01 with the Nav. I hooked up my Ipod by disconnecting the factory CD changer and hooking up the ipod to the cd input. Now, when you push the cd button in the cabin, the ipod come on....works just fine!
Old Jun 14, 2008 | 12:58 AM
imolafem's Avatar
What did you use to hook up the iPod to the cd changer port?
Old Jun 14, 2008 | 08:27 AM
Turbo Fanatic's Avatar
I've heard good things about the Dension Ice Link
http://www.dension.com/icelinkone.php
All you need is the head unit removal tool (like $1 on ebay) and it's a total plug and play. 5 minutes to install. Make sure you get the pre-03 kit (those are fiber optic). I hear it just runs on the "aux" setting on stock head unit. http://search.ebay.com/search/search...tool&category0=
I know bumber plugs carried them for a while?
I want one too if you locate what unit it is.
Old Jun 14, 2008 | 09:52 AM
Imolas54's Avatar
Imolas54 is infamous around these parts
This is what i found,
http://www.discountcarstereo.com/detail.aspx?ID=993
just need to tap into the ground/power from the radio harness and it's plug and play. It does not control the ipod but does charge it. I was unable to find any fully intergrated ipod solution for the 01 996....
just remember after the install you have to enable the aux function thru the radio. http://www.beckerautosound.com/pdf_g...directions.pdf
Old Jun 14, 2008 | 10:37 AM
vv23's Avatar
Is the ipod controllable from the factory Deck? If so, What did you use to connect?
Old Jun 14, 2008 | 10:58 AM
smistry007's Avatar
I used a 6 foot length of speaker wire with RCA connectors on both ends. One end plugs into the cable that is disconnected from the cd changer in the trunk. The other end is plugged into an RCA-1/8 inch adapter that plugs into the ipod. All equipment available from Radio Shack.
To use the ipod, just push the cd button on the head unit. To switch songs on the ipod however, you still need to use the ipod controls.
hope this helps
Sameer
Old Jun 14, 2008 | 11:59 AM
I pulled out my stereo to look back there and couldn't get the keys out!
Here is to remove the keys once they're in
http://www.pro-fit-intl.com/Adobe/DM-20-22.pdf
Old Jun 14, 2008 | 12:56 PM
imolafem's Avatar
Does anyone have experience with the Dension IceLink on their Turbo w/ nav?
Old Jun 14, 2008 | 01:38 PM
MikeR's Avatar
MikeR is infamous around these parts
I ended up doing the same, I have an '01 with Factory Nav. Not the best way, but it works.
Old Jun 14, 2008 | 02:34 PM
vv23's Avatar
Is there any way to control the ipod with the factory deck?
Old Jun 14, 2008 | 02:42 PM
gareeb's Avatar
gareeb has much to be proud ofgareeb has much to be proud ofgareeb has much to be proud ofgareeb has much to be proud ofgareeb has much to be proud ofgareeb has much to be proud ofgareeb has much to be proud ofgareeb has much to be proud of
I ordered the becker Aux in cables and then bought a little switch box to plug the cd changer and Aux into. The switch box is in the glove box now I can switch between the two.
Old Jun 14, 2008 | 10:13 PM
FlyYellow's Avatar
FlyYellow is infamous around these partsFlyYellow is infamous around these parts
i have on of the denison units that integrates into factory becker (non-nav) unit. It replaced the CD changer and you utilize playlists 1-6 and it directly controls and drives the ipod. pretty cool. i am willing to part with it as i changed my setup. i'll sell it for $110 + shipping (that's what i paid for it)
