Are Diverter valves needed for an ECU tune?
Old Jun 23, 2008 | 04:08 PM
  #31
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
Originally Posted by Seal Grey Matte
What type of DVs do you have? Sounds like they are leaking. And yes, aftermarket DVs can seize and/or leak. All a DV does is divert the charged air from the TB back into the turbo's impeller blades. The valve opening should be a silent event. The reason BOVs make "pssh" sounds is that they vent that air into the engine compartment rather than into the intake track. If you are getting a psssh, air is probably going where it isn't supposed to.
You should remove them and pressure test them.
They are EVOMS DV's. Yes, I am familiar with what DV's do, and the reason I can hear them is because of the V-flow. When shifting and the TB shuts, all that charged air goes thru the DV's and back into the intake plenum. Since the filter on the V-flow is very near where the DV's route the charged air, that is why it's more audible. Before I put the V-flow on, I could never hear them working.
Old Jun 23, 2008 | 04:15 PM
  #32
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
Sorry if I was a bit pedantic there. The honking really gives me a concern though. At very least, the internal piston probably needs to be lubricated. If it were me, I'd still pressure test them.
Old Jun 23, 2008 | 04:19 PM
  #33
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Originally Posted by Softronic
Well Boca you can always settle for less and not get the Softronic. Then again you already have another agenda
By the way Softronic has standard flashes and custom tuned flashes. These are sold by many different distributors and some labeled as there own also.
Oh no, not another Flash War!
My rule of thumb is... never say anything bad about anything unless you experienced it yourself.
"Then again you already have another agenda" +1.
Old Jun 23, 2008 | 04:20 PM
  #34
No worries. I'm 99.99% sure it's the V-flow, and I have heard others say the same thing after installing a V-flow. I will lubricate my DV's though...any idea what to lube them with???
Old Jun 23, 2008 | 04:23 PM
  #35
That is a good plan, and I agree 110%!!
Old Jun 23, 2008 | 04:25 PM
  #36
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
Yes it's the V-flow,I can hear mine DV's very good because I have an open air filter and when I put stock airbox in I don't hear them at all...
Old Jun 23, 2008 | 04:32 PM
  #37
I think Forge recommends Mobil 1 synthetic grease. Good luck! If you're going to go through the trouble of cracking them open to service them, you might as well pressure test them too. You don't need any special equipment aside from the palm of your hand.
Old Jun 24, 2008 | 07:05 PM
  #38
vividracing's Avatar
Diverter valves are necessary at the increased boost. Vivid Racing uses Forge Motorsport valves the original one everyone has copied
Why would you say stay away from Softronic? Softronic is one of the best ECU flashes available. I have used 3 different companies myself. I would gladly discuss them with you on the phone.
Old Jun 24, 2008 | 07:14 PM
  #39
WOODTSTER's Avatar
DV == Mad Power (tire shreading performance...hold on)
Sep 1, 2015 03:16 PM
albert@velosdesignwerks
BMW //M
Aug 22, 2015 07:17 PM
Fadi
Aug 21, 2015 03:43 AM
Aug 19, 2015 06:55 PM
