engine misfire
Old Jun 26, 2008 | 09:48 PM
Carter Beck's Avatar
Carter Beck is infamous around these parts
engine misfire
my engine misfires and gives a CEL with hard acceleration. People tell me this is most likely fouled plugs. it did this before and after a stage one. any advice?
Old Jun 26, 2008 | 09:53 PM
just read the thread below. similar problem but not exactly the same, does MAF malfunction throw a code?
Old Jun 27, 2008 | 01:25 AM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
its plugs for sure if the CEL blinks and it stutters
Old Jun 27, 2008 | 09:57 AM
thanks 996,
i have read the one million posts on this. I think it could be either plugs or MAF.
Old Jun 27, 2008 | 10:49 AM
ard's Avatar
ard
You refer to 'the post below'... all posts are moved within each forum as comments are added...just fyi.
Easy way to check. Take out the MAF, clean it well. If it improves it was the maf and not he plugs.
How many miles on your plugs? If over 20k, definitely time to replace anyway.
Finally once plugs are replaced, and remaining issues replace the MAF. They do eventually get fouled where they cannot be cleaned (not this is different than a 'blown' maf)
Personally, I view mafs and plugs as maintenance items, so the need to have a definitive diagnosis is low. They will eventually need replacing....
A
Jul 29, 2019 11:13 AM
vr6tee
Aug 29, 2015 03:52 AM
oddjob142
Aug 24, 2015 05:49 PM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
