No5 Misfire
Old Jun 29, 2008 | 04:08 AM
andymac's Avatar
andymac is infamous around these parts
No5 Misfire
Noticed my idle was a bit lumpy?
Mechanic plugged in the PWIS and there was no error codes. But it showed a misfire on cylinder 5. I changed the coil pack and the plug but it made no difference?
Changed the MAF just in case and it did go but now its back ?
Any ideas
Old Jun 29, 2008 | 04:09 AM
andymac's Avatar
Just to add. On full throttle I get no misfire. Its only on idle??
Old Jan 19, 2009 | 01:18 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Any update on this? I am having the same problem right now....
Old Jan 19, 2009 | 05:56 AM
andymac's Avatar
I changed the diverter valves and the boost hoses. The lumpy idle disappeared again. Did a track day the other day and it came back.
Next plan is to change all the plugs and all the coil packs to the 997 version.
I've read somewhere just because a misfire is showing on 5 it doesn't always mean thats the one with the problem
Old Jan 19, 2009 | 07:55 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Do a full set of plugs, change cylinder 5 coil and drive the car. If this still doesn't correct the issue and its still isolated to cylinder 5, I would consider replacing the injector.
Old Jan 19, 2009 | 08:40 AM
VAGscum's Avatar
Tony, does this car have ignition amplifiers/control modules like the older porsches and audis? That might be another possibility.
Old Jan 19, 2009 | 10:22 AM
Tony@epl's Avatar
Nope, the ignitor/amp built into the coil.
Old Jan 19, 2009 | 11:18 AM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
I had that same problem. Switched all plugs and all coil packs at 60K mile service. No problems after that.
Old Jan 22, 2009 | 02:30 PM
andymac's Avatar
A While back a garage changed the coil pack and plug on number 5 but this didn't help.
The car drives fine, I took it on track and it didn't miss a beat.
But when I got home it had the occasional miss when on idle. It only does it when warmed up ??????
My next plan is to change all plugs to the Bosch ones and the coil packs to the 997 version. My car is a 2001 and I think they're the originals.
Old Jan 22, 2009 | 05:18 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
Here is my input....
if you do a seach you will find my traed about bad idle...story short after changing MAF & all the coil pack for the 997 versio & plugs & DV the car runs much much faster and smoth...but the warm up missfire #6 /total + hasmatic/fart idle was there on cool starts.
Today is getting better and better + the car is runing smother and faster , the solution was to drive and drive and drive and drive the car.... did I say drive ...yes drive and from time to time use Liqui Moly Flue Injection Cleaner, there are good options in US, to a seach on 6sp about that topic. In my case my TT was too much in the garage on 2007 and big part of 2008.
I hope its helps!
http://www.youtube.com/watch?v=VVrRxlKFzmQ
Old Jan 22, 2009 | 05:25 PM
ohh sorry you in UK....sure you will find Liqui Moly....read the instructions and drive and drive and drive...
Old Jan 22, 2009 | 05:37 PM
ttboost's Avatar
subscribed...very interesting. I have had a #5 cylinder misfire for months now. Been driving it and no noticable issues. I had someone log it with Durametric a couple months ago, but never did anything about it. I changed all my plugs about 4 months ago and 1 bad coil as it broke up on the dyno.
Old Jan 22, 2009 | 06:00 PM
dgreen78's Avatar
My misfire reads as a constant count reading it with Durametric software. Feels like its running on 5 cylinders and very rough.
Will be changin the plugs and all coilpacks tonight, will report my findings.
Old Jan 22, 2009 | 06:08 PM
ttboost's Avatar
Mine misfires cyl #5 at 2500 rpm's, but runs mint...
Old Jan 22, 2009 | 11:30 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
TT, Does it happen at steady, light throttle, but not on acceleration?
