Toyo R888 cold/hot pressures for track
Old Jul 16, 2008 | 02:21 PM
iLLM3's Avatar
Originally Posted by oak
Nice, what kind of camber and caster are running? No rubbing at all? Are you using these with with Stock GT2 wheels/size offfsets?
Over -2 camber, caster/toe not sure, I have the spec sheet as it's constantly being changed after track events...
No rubbing unless making uturn full lock but in the front, weird since Tom Kerr is running 255's up front... It's a perfect setup though, 335's in rear for you though, you will need to modify or cut out the inner plastic fenders or add the GT2 fenders. Ask Tom kerr, he has the solution!
Old Jul 16, 2008 | 09:36 PM
oak's Avatar
oak
ill, cars lookin sweet, I have a set of stock 04 GT2 wheels and would like to run the 335's and 245's on my turbo. are your wheels stock GT2 offsets? thanks.
Old Jul 17, 2008 | 01:18 AM
iLLM3's Avatar
I don't think they are identical GT2 offset, but very close just a tad bit more aggressive! You will not have an issue with these tires on those wheels, especially in those sizes BUT WITH different alignment settings or minor changes within the F/R fenders lining
Old Jul 17, 2008 | 12:58 PM
AdrianM5's Avatar
AdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to all
Originally Posted by boss351
Adrian, stock TT or GT2 wheels? No rubbing?
stock tt wheels no rubbing!
Old Jul 18, 2008 | 12:14 AM
oak's Avatar
oak
thanks ill I think I'm going to try a set in 335/245. where would you recommend sourcing a set?
Old Jul 18, 2008 | 12:19 AM
iLLM3's Avatar
Good pricing The grip is IMMENSE... No more traction issues for me really
http://www.1010tires.com/tire.asp?ti...el=Proxes+R888
Old Jul 18, 2008 | 03:48 AM
oak's Avatar
oak
I didn't realize you were located in Canada! 1010 is located in BC. I'm located in So Ca. I'll check locally. Thanks for the info.
Old Jul 18, 2008 | 10:40 AM
fotostars's Avatar
fotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud of
good info. Thanks for sharing. I wasn't sure 315 could run on stock wheels
Old Jul 18, 2008 | 10:49 AM
boss351's Avatar
boss351 is just really niceboss351 is just really niceboss351 is just really niceboss351 is just really nice
My concern exactly also. The 295 R888's on stock 18x11 fit like a glove. The sidewall is flat, not angling out at all, and very very stiff. Great fit. I'd like to see a shot of the 315's mounted on a 18x11 also and here on how stiff the sidewalls are. What are they like to track on?
Old Aug 31, 2008 | 09:24 AM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
Old Aug 31, 2008 | 10:03 AM
tom kerr's Avatar
I run 265 up front on 9" wheels stock offset. 335's on 12's in rear. -3 camber.
Old Aug 31, 2008 | 10:08 AM
jenk12m's Avatar
jenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant future
thats some rubber there!!
car looks great tom
Old Nov 11, 2008 | 04:37 AM
contigo's Avatar
I am doing cold 26 F and 33 R Hot 32 F and 39 R
Old Nov 12, 2008 | 12:43 AM
iLLM3's Avatar
Originally Posted by contigo
I am doing cold 26 F and 34 R
34 cold in rear will get well over 40 hot pressures, you want to be at 36 hot rear!
Old Nov 12, 2008 | 06:39 AM
tom kerr's Avatar
car looks great tom
thanks need all the help I can get.
got to admit though, I ran 275/335 Hoosiers at Daytona last week and man I forgot what an massive increase in grip they have over the Toyo's and Cup tires!!
once you run them its hard to run anything else.
I still drive my car to the track sometimes and cant beat the Toyo's for this but I will drop 2-3seconds with them compared to Hoosiers.
