Alignment gurus, please chime in
Old Jul 6, 2008 | 11:23 PM
kcphuah's Avatar
kcphuah is infamous around these partskcphuah is infamous around these parts
I drive my car relatively agressive and in soem situation when I change lane as the boost kicks in, I almost feels like losing the car for a quick sec before gaining control. In addition, my car has a floaty feeling to thh front when I hit a slight curve at a speed rate of 70 mph, this is much more obvious as gas it.
I recently had my alignment done and wonder if adjustment to any of the following can help me to improve the handling or at least mnimize the floaty feeling.
Front Camber Left = - 0.17
Right = - 0.23
Front Toe Left = 0.03
Right = 0.02
Rear Camber Left = - 2.02
Right = - 1.59
Rear Toe Left = 0.10
Right = 0.11
Any ideas? Thanks in advance for helping out.
Old Jul 7, 2008 | 12:53 PM
Bos's Avatar
Bos
Bos is infamous around these parts
No expert, but... Rear camber looks high in relation to the front. The specified camber range for rear is -1.7 ~ -1.2. Not to mention, I would think they could get left & right camber closer to each other.
Old Jul 7, 2008 | 01:09 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Found this spec sheet from Dan's post. Dan's car has more front camber than yours. Post out the other spec. numbers and we will have better idea.
https://www.6speedonline.com/forums/...Alignment+spec
Old Jul 7, 2008 | 01:53 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Are you on stock suspension?
Old Jul 7, 2008 | 02:33 PM
Ray's Avatar
Ray
His TT is running PSS9
Old Jul 7, 2008 | 02:34 PM
Joe Weinstein's Avatar
You want more negative camber in the front if you want to stick
the front in corners. You want zero toe in the front and a little
toe-in in the rear.
As Stevo asks, are you on stock suspension? Much ugliness can
come from poorly installed suspension parts (needing a corner balance).
Joe
Glasgo
Nov 30, 2015 02:37 PM
Jbranda
Oct 31, 2015 04:53 PM
miken168
Oct 6, 2015 09:21 AM
Ronny-
Sep 30, 2015 07:30 PM
DSC Sport
American Muscle
Sep 23, 2015 10:51 AM
