Oil Burning
Oil Burning
Just brought my 2001 996 tt in for its 30,000 mile service. It is still buring a quart of oil every 600 miles....is this normal? Porsche claims it is, because I drive the car hard...I don't...please advise.
Sounds a little high to me unless you drive under extreme conditions. I recently bought a 03 911 cab and was also concerned with excess oil consumption. I posted about it here, but did not get much response. My use is more like a quart/200 miles. My dealer is talking about an engine replacement. They had to document the usage 3 times and he put in a request for an engine and now we wait and see. I'll post when I get an answer.
Neil
Neil
I burn oil at about 1qt. per 600 miles but I only have 6000 miles on my car. At 30,000 miles everything should be seated. Maybe someone else can chime in here but I believe burning oil at that rate with 30,000 mile is a problem. Historically Porsche motors burn alot of oil up to 8,000-10,000 miles when everything seats and then consumption drops dramatically.
- KJ
Might also depend on your engine break-in program. I'm looking at about 1/4 quart every thousand or so miles. I was ultra-conservative in breaking in the engine. Also, I don't drive it THAT hard (use around 4K as the initial shift point and keep cruising revs at between 2K - 3K, street use only. I recall that 1 quart every 600 - 650 miles is at the high end of the tolerance level. I think it would be considered acceptable, not normal, meaning - you don't get a new engine :-).
Originally posted by Ruiner
I have 22,000 on mine and still burn about 1 qt every 900-1200 miles (depending on street vs highway miles). It might actually be less, but most of my miles are highway miles.
Originally posted by collin996tt
Also, what's the burn rate on GT2 and GT3?
I've been watching this thread. Coming from japanese cars I find it unusual that these cars are designed to burn oil and that different cars in the same group burn different amounts. Here I'm burning so much I may need a new engine and someone else I know with the same car runs 6000 miles and burns no oil. What gives or does this just go into the "oh well" catagory?
Neil
Neil
