Disc thickness
Old Jul 20, 2008 | 09:52 AM
andymac's Avatar
andymac is infamous around these parts
Disc thickness
Anyone tell me the thickness of the brake discs when they are new and when they need replacing?
Andy
Old Jul 20, 2008 | 10:00 AM
andymac's Avatar
sorry, found this on Renntech:
Brake disc thickness, new -- front 34 mm, rear 28 mm
Minimum brake disc thickness after machining* -- front 32.6 mm, rear 26.6 mm (* The brake disc must only be reworked symmetrically, i.e. from both sides evenly.)
Brake disc wear limit -- front 32.0 mm, rear 26.0 mm
Peak-to-valley surface roughness of the brake disc after machining, max. -- 0.006 mm
Thickness tolerance of the brake discs, max. -- 0.02 mm
Lateral runout of the brake disc, max. -- 0.03 mm
Lateral runout of the wheel hub, max. -- 0.03 mm
Lateral runout of the brake disc when installed, max. -- 0.06 mm
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
TOGWT
Detailing
Oct 1, 2015 07:59 AM
