Stereo Upgrade for MOST System
Old 03-22-2019, 03:31 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
I'm confused about this method of replacing the factory amplifier. The factory Bose amp is 7 channel, so how are all 7 channels being powered by 5 channels.
Old 03-22-2019, 09:55 PM
Stebo's Avatar
Stebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond repute
I used a JL 6 channel amp:
Put my dash right and door right in parallel on 1 channel
Put my dash left and door left in parallel on 1 channel
Right rear alone on 1 channel
Left rear alone on 1 channel
Bridged channel 5&6 for my sub
Old 03-22-2019, 10:46 PM
split's Avatar
I thought all the speakers are 2 ohms. Wouldn't that mean your dash/door combo would be only 1ohm when wired in parallel?
Old 03-23-2019, 07:16 AM
Stebo's Avatar
I replaced all of my speakers with 4 ohm units.
For stock speakers with an aftermarket amp, see this link
https://cai-store.com/pages/996-cabr...-new-amplifier
It's a pretty good website with a lot more good info than just that article. Definitely browse around it. They have done a bunch of Porsche stuff and actually share the info which is nice!
I ordered some stuff from them, but ended up going my own way on the hardware. E.g. the 6 channel amp. Got it all from crutchfeild. I felt like the 5 channel amp was janky with stock speakers, and in the end I elected to do the whole shebang.
To answer your question: it looks like the guys running 5 channel amps have aftermarket subs.
Old 03-25-2019, 07:15 AM
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
If you're not looking for audiophile quality and don't want to spend a buttload on a project like this, the 5-channel amp option is actually great and you can use the stock sub.
I upgraded the dash speakers to some 5.25in JBL 2-ways and ran them directly off the aftermarket head unit front channel. I then ran each of the remaining factory interior speakers off of 4 of the 5 channels on the amp. I rewired the factory sub speakers in series to bring them up to 4 ohm and ran that off of the 5th sub channel on the amp.
Old 03-25-2019, 05:19 PM
Stebo's Avatar
I probably should have mentioned that I have a Cabriolet, which only comes with a single 1 ohm sub. It definitely affected my decision making process.
Old 03-25-2019, 09:28 PM
vogz's Avatar
Ah, details, haha. I now see the cab in your avatar.
Old 03-28-2019, 08:34 AM
techweenie's Avatar
techweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant future
I also have a Cab that came with MOST. Del Rey Customs fixed me up with a 5-channel Alpine amp, hardwired to a touchscreen/CarPlay head unit. Sound is okay, as I haven't replaced the speakers, but as a first step, it's not too $$$$ painful.
Old 03-28-2019, 10:21 AM
Stebo's Avatar
They likely put the sub in series with one of the doors...
I can figure it out if you take a close-up picture of the speaker wires coming out of the amp.
Old 03-28-2019, 05:03 PM
techweenie's Avatar
Here you go.
Old 03-28-2019, 05:39 PM
Stebo's Avatar
Isn't that the input side? 3 pairs of rca... there should be another bunch of wires coming out... that or your amp came with special wiring harnesses for each channel and the terminations are done downstream somewhere.
I landed my speaker wires directly on their respective channels that way I could tell what was going where, like this:
Old 03-28-2019, 05:41 PM
techweenie's Avatar
Duh, sorry, yes, input side. But the other side is not accessible.
Old 03-28-2019, 05:54 PM
Stebo's Avatar
I'd like to see it, if you dont mind
I mean just zoomed out, such that I can see the wires. Want to see the install as it sits. I'm not asking you to tear it apart.
Something like this
Old 09-07-2022, 01:22 PM
G8rJimbo's Avatar
G8rJimbo is an unknown quantity at this point
Stebo,
Checking to see if you're still on. How did you mount that amp to the carpet area in the Frunk?
Something like this
Attachment 532255
Old 09-07-2022, 01:40 PM
Stebo's Avatar
I'm still on... but when i switched back to apple from android, I can't find the damn forum in the app store, so I'm around A LOT less. Anyway, I made a custom mount using a piece of plywood that I covered in carpet. then, I bent some metal ( i think it was a galvanized simpson strap from home depot), drilled out the mounting holes, painted it black, and used the factory bolt and one of the attachment points for the CD changer on the fire wall. Unfortunately, my car is in storage at a buddy's house otherwise I'd run out there and take some more pics.
If you look close in the pic above you can see what i'm talking about. But yeah, totally custom. I got the carpet from a local car audio shop - thinking back on it - I had them use their spray glue and carpet to wrap it for me. It came out great. The carpet matches so well, that it is impossible to tell. I screwed the amp to the plywood and then bolted the plywood to the firewall.
It just sits there and is held in by the one bolt that you can see. It's totally secure and I drive like a maniac.
Quick Reply: Stereo Upgrade for MOST System
