First Check Engine Light
Old Aug 14, 2008 | 10:35 PM
  #31
ard's Avatar
ard
Was it a new exhaust? How sure are you of the CAT conditions?
When I was shopping for used, a wise tuner told me a high res picture of each cat was essential to assess potential damage
Wierd it is both sides... any chance you mixed up which o2 sensor goes to which hole?
Old Aug 15, 2008 | 10:09 AM
  #32
Flyfisher's Avatar
Flyfisher is infamous around these parts
ard, yes it was a brand new exhaust--a Fabspeed Gen 3 Quiet. Possible I mixed up the sensors, but I don't think so. I had marked the leads with masking tape. But bear in mind that I'm the same guy who thinking back to the install only thought he installed one O2 sensor per side
A gave the car a good stretch last night and so far the CEL light has stayed dark.
Old Aug 20, 2010 | 04:38 PM
  #33
Project911's Avatar
Project911 is infamous around these parts
Originally Posted by ttboost
Is it possible his cats are a little too free flowing? tripping out the rear O2's? Anyone else have this problem?
I'm having the same issue and after resetting the CEL it will eventually come back on. The code I get is P0430, something with the 02 sensor. Checked the code again at a shop and it turned out to be the cat. I was told to add extensions to the 02 sensors to trick them out.
Old Aug 20, 2010 | 06:48 PM
  #34
Flyfisher's Avatar
What do you mean by adding extensions to the 02 sensors? I still have the issue. I'll reset the system, and sometimes I can go weeks before the CEL pops on. Other times, it pops within a few hours. If you have a fix without getting more efficient cats, I'd like to know.
Thanks,
ken
Old Aug 20, 2010 | 06:52 PM
  #35
ttboost's Avatar
Thanks,
ken
They are basically O2 bung extensions that thread into the existing bung and then you thread your O2 back into it, to get the O2 out away from the flow of exhaust gases... less sensitive...
Old Aug 20, 2010 | 06:54 PM
  #36
Flyfisher's Avatar
Thanks. I'll look into them.
Ken
Old Aug 20, 2010 | 07:15 PM
  #37
Project911's Avatar
That's absolutely correct! I am about to try that soon and see if it works. Yeah the CEL comes on randomly...
Old Aug 21, 2010 | 12:46 PM
  #38
r34dy2walk's Avatar
r34dy2walk is infamous around these parts
I had the same issue as well. We concluded it was indeed because the new exhaust was more free-flowing than the stock exhaust.
Old Aug 21, 2010 | 02:33 PM
  #39
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Ken
Hi,Have a look at this page from design 911:
http://www.design911.co.uk/fu/pt63_4...sors---Probes/
Frank
Old Aug 21, 2010 | 05:30 PM
  #40
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Anyone knows a good and cheap source for O2 sensors?
Old Aug 21, 2010 | 06:20 PM
  #41
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Originally Posted by drh
My CEL came on again after having the 30k done. I suspect it has to do with the new exhaust system. At any rate, I disconnected the battery for 1/2 hour, reconnected the battery and the CEL disappeared and has yet to return after a few hundred miles. The Radio code must be re-entered when doing this...just as a heads up.
That's what i do when CEL comes on and if it goes off....good,if it doesn't i take her to the dealer.
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
The Oss
Aug 24, 2015 08:19 PM
