Real world differences between GT 3076 and GT 3071
Old Aug 11, 2008 | 06:20 PM
OhioGT2's Avatar
OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !
Originally Posted by Divexxtreme
830/780 at 1.41 BAR on Todd's dyno...but then I ran out of turbo. All I got with more boost was more torque. I think they were pretty much maxed out by that point.
I loved 'em, though. They actually made more power at 1.4 BAR than my 35's do....but I didn't want my overall HP to be limited by my turbos.
Yes, my point exactly....you were 100+hp over my numbers with same turbos and headwork, on the same optimistic dyno.
I found the .82's much more fun to drive...the .63's really died up top. I didn't feel I lost much spool either, maybe 200 rpm....
Old Aug 11, 2008 | 07:15 PM
RCNJ's Avatar
RCNJ is infamous around these parts
Don't mean to hijack this thread but just curious to know what kind of power you guys think I'll make on my build.
3.8L CP forged pistons with 102 mm ductile liners
Pauter rods
O-ringed head and liners
Racewear headstuds
Full Proto intake with FORD maf
75mm IPD plenum
Evoms IC's
Custom exhaust with just resonators (no cats)
60lb injectors with in-tank and external pumps and bigger fuel lines
HTA GT3076. 82 a/r
We plan to run 1.5- 1.6 bar 0n C16
Old Aug 11, 2008 | 07:30 PM
Divexxtreme's Avatar
Pauter rods
Racewear headstuds
75mm IPD plenum
Evoms IC's
HTA GT3076. 82 a/r
With stock cams and heads I'd guess 750 rwhp or so.
Old Aug 11, 2008 | 07:46 PM
Dr_jitsu's Avatar
Sounds about right Scott although I think he will need 1.6 to hit 750. But w/ the strengthened bottom end he can get away w/ it.
Here is some info I found explaining the Garretts:T30R(GT3076) uses a 52lb compressor, the GT3071 is ~49lb.
The 71 & 76 is the exducer diameter in mm of the compressor, not the AR. Both 71 & 76 use the same exhaust wheel just a different exhaust housing(AR), most use .63 or .82 A/Rs for the Garrett GTs. You must take into account that the Garret wheels are much much lighter than the MHI wheels so a larger A/R does not necessary mean its going to be laggier than a smaller ^cm MHI.
Old Aug 11, 2008 | 08:21 PM
RCNJ's Avatar
Scott,
In your opinion would I gain more hp with the HTA GT35 .63a/r turbos? Would this be a better choice turbo and whats the max boost I can run safely?
Raudel
Old Aug 11, 2008 | 08:57 PM
Scott,
Raudel
You do not have the fuel for gt35rs.. remember we talked about it....
I think the twin 044 pump set up with 60 lbs. injectors are good for 750rwhp just like Scott pointed out.
Run the boost/fuel that Todd recommends.... I say nothing but C16 on high boost... 1.5 bars I guess... 1.2 bars( 104 octane)...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 11, 2008 | 09:48 PM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
The 60lbs injectors will give you 700 flywheel HP at around 85% duty cycle with a 5 bar FPR.
The dual 044s will take you beyond 1200 flywheel HP without problems, so your limitation are the injectors.
Old Aug 12, 2008 | 05:34 AM
Scott,
Raudel
Raudel,
I agree with Mark and Jean. Your limitation will be your fuel system. For you what you have now, I'd stick with the GT3076's. I absolutely love those turbos.
Old Aug 12, 2008 | 06:34 AM
WOODTSTER's Avatar
Sidenote to a great discussion:
The turbos that came off from Scott's car (GT30/76's) are available as I sold
them to a buddy here on 6speed. (S-351). He has decided not to put them
on his GT2 for now.
MK
Old Aug 12, 2008 | 07:29 AM
Dr_jitsu's Avatar
Marty,
How much?
Old Aug 12, 2008 | 07:51 AM
RCNJ's Avatar
Mark,
The fuel system is being upgraded. Right now I only have 60lb. inj., and one external 044 pump. We are going to add an in-tank 044 pump and run bigger fuel lines. Todd said with this setup I will be good to 850 rwhp.
Old Aug 12, 2008 | 10:01 AM
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
Sound interesting!!
Keep update us gents!!
Old Aug 12, 2008 | 10:19 AM
SpeedYellow's Avatar
SpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura aboutSpeedYellow has a spectacular aura about
Ahaa!!!
Mark,
So with all of the Q's surrounding the smaller injectors, it would turn out that Todd has plans for more fuel all along......
Old Aug 12, 2008 | 11:13 AM
Mark,
I recall you telling me the fuel stuff was being left alone a few months back...
Good stuff...
9.66
click to view
Old Aug 12, 2008 | 11:42 AM
RCNJ's Avatar
Good stuff...
Yeah, I know but you know how it goes. These projects tend to snowball.
