The best wheels?
Old Aug 13, 2008 | 06:40 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Originally Posted by ssmugen
Are you saying go with a 245/40/19 and 325/30/19? How does the difference in rolling diameter compare to the ever popular 235/35/19 and 315/25/19?
It depends on the tire. Each tire has a different rolling diameter.
Originally Posted by landjet
Before you spend your money, make sure that the wider tires and GT2 wheels are going to fit without rubbing. You may have to change your wheel well liner for the GT2 liner. My stock 295/30/18 rears sometimes rub a little. I know because I found an abrasion area on the wheel liners on both sides.
Yes please do this. If you go with a GT2 offset and wider tires you may have to roll your fenders.
Old Aug 13, 2008 | 08:38 PM
Turbo Fanatic's Avatar
The main difference is that GT2 offest wheels are 1/2" wider front (8.5") and 1/2 to 1" wider in the rear (12"). If you are paying big money for new wheels they better be as wide as will fit.
They'll fit fine. You may need to roll the rear fenders. Either professionally, or with a 2lb mallet (like I did).
Originally Posted by EZ Cookin
Ari, do most wheel dealers know what the GT2 fit is? And can you get the GT2 fit with 19's?
Old Aug 14, 2008 | 12:41 AM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Originally Posted by ari
If you go with new wheels make sure you get the "GT2" fitment wheels. They are usually marginally wider and fit fine once you roll the rear fenders like the factory GT2 cars come.
I use and recommend Champions. GREAT lightweight wheels.
When going 19s consider 30 series rear sidewalls and compensate on the fronts by going a bit wider (245s?). You will get a bit more rim protection due to the slightly taller sidewalls and slightly taller gearing which never hurts in 1st and 2nd on these cars.
12" in the rear with a 305/30/19?? In this case, the rim would stick out further than the tire's sidewall by alot.
ssmugen was refering to specific sizes of 245/40/19 325/30/19 vs the popular 235/35/19 315/25/19 setup....
Rolling diameters on 245/40/19 + 325/30/19 is .04 difference; the problem is getting them to fit.
235/35/19 + 315/25/19 has a difference of .27.
I highly doubt a 245/40/19 will fit without major rubbing issues. I run a 245/35/19.
Old Aug 14, 2008 | 01:03 AM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
Thanks everyone for your help. I will probably do a coil over set up at the same time. will this make a difference on the wheel size? Are spacers used for cosmetic purposes only?
Old Aug 14, 2008 | 01:05 AM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
Bingo! thanks for playing.
Old Aug 14, 2008 | 01:52 AM
Spacers are used to do exactly that. Space your wheels out a bit more.
IE I can fit 15mm spacers rear and 7mm front with my 8.5" / 11.5" champions and 235/315s (the usual setup). IMO the 25 aspect tire leaves your rims very exposed to damage.
I also run a 255/35 18 on stock 8.5" GT2 spec wheels with no problems. You can usually fix front clearance issues with a tad more camber. These cars are very easy on their front tires anyways. You get 2:1 wear Rear /Front with the rears lasting half or less than the fronts.
Again this is all personal opinion. There are people running 265/335s with minimal rubbing on this board. Ask Sharky. It can be done.
Old Aug 14, 2008 | 02:11 AM
Slow4s's Avatar
Slow4s has a spectacular aura aboutSlow4s has a spectacular aura about
Originally Posted by mannytt
HRE P40's
821 Posts and your answer is HRE? You got to be kidding me....
HRE AND BBS don't even compare, although HRE are better for "show" and "bling".
BBS also makes all of the wheels for Porsche.
Old Aug 14, 2008 | 06:34 AM
boss351's Avatar
boss351 is just really niceboss351 is just really niceboss351 is just really niceboss351 is just really nice
Originally Posted by STALKER
IMO, its gotta be a fully forged wheel.
Champion wheels are a once piece 8000 ton forged pressed wheel. That means they light and extremely durable. Only a handful of factories can produce wheels in this fashion, and most are in Japan. They are $$$, but you get what you pay for.
I have gone through 2 sets of HREs on my M3 and hated them. IMO, Champion, NEEZ, BBS and OZ make the best wheels on the market.
Take a look at Volks (Rays Wheels), great 1 piece forged from Japan. Good bang for the buck also.
Old Aug 14, 2008 | 07:14 AM
damon@tirerack's Avatar
Moderator
In kinda late, but I'd love to answer any questions you may have.
From a quality and heritage standpoint alone you won't do better than BBS or OZ, and we are the country's largest distributor of both. We also carry Volk.
Please give me a call.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Aug 14, 2008 | 07:47 AM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
DYMAG FTMFW
Old Aug 14, 2008 | 10:46 PM
Zippy's Avatar
Old Aug 14, 2008 | 10:56 PM
Slow4s's Avatar
How wide are the rear tires? ^
Old Aug 14, 2008 | 11:09 PM
///M_Chap's Avatar
///M_Chap is a jewel in the rough///M_Chap is a jewel in the rough///M_Chap is a jewel in the rough///M_Chap is a jewel in the rough
Originally Posted by alex55
Bbs Lm !
PICS!!
Please add pictures of the wheels on the car while making suggestions (soley for my viewing pleasure...)
Old Aug 15, 2008 | 06:02 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Originally Posted by ///M_Chap
PICS!!
http://www.6speedonline.com/forums/a...lms-tires.html
Old Aug 16, 2008 | 09:32 AM
EZ Cookin's Avatar
What type of wheel weight should I be looking for? Range?
