Is it new battery time?
My car is a 2001 with 17,000 miles, it was sitting for 12 days and the battery is dead, do I need a new battery or just to charge my existing one?
The real problem is my car will be in FL soon at an apartment complex and I will not be able to keep a battery maintainer and will be in NY for sevral days at a time, how long can a Porsche sit without the battery going dead?
Originally posted by JASCLASS
Ron, You can get a quick battery disconnect for when you arent useing the car.
AGM type is the same general principal as an Optima
It is a larger sealed battery, you have to move your hold down to the next hole and insert a nut under the bolt
The AGM has much more cranking power and is able to sit dorment for long periods of time, you will notice the car cranks much faster
Hope this helps you
Hope this helps you
The car electronics pull about 50 ma so that is about a 1 amp drain per day. The porsche battery is about 70 ah so theoretically it would last about 2 months. However in general you should not let the charge drop below about 75%.
Originally posted by Rave TT
Could you elaborate please, how long will sit before dying? Thanks.
Jul 29, 2019 11:13 AM
