IPD Plenum installed by Turbo Mike himself!!!
Not sure if you're talking to me Dr_jitsu. If you were, my car is a Tip and doesn't go well with dyno. I sold my Pbox to one of the board members thinking I won't be needing it, I guess I was wrong.
Understood! That was a perfectly legit question. However, I cannot answer it due to my car's limitation.
Couple of quick questions for those that have installed the IPD 75mm plenum:
- Are all the bolts for the oil filter assembly accessible when the y-tube and throttle body are removed?
- Is the diverter assembly removed as well?
- What's the best way of removing the hose clamps on top of the OEM plenum?
- Any other install hints?
Thanks in advance!
Thanks in advance!
Not necessary, but you can lower the motor for better access. Have fun with it, I know that IPD guarantees their plenum makes the power.
Mr. Sid, long time no talk. When are you guys running again in Mexico? I got a PM from Robert but no follow ups. I left him a VM. Are you guys still running?
Remove the air box, y-pipe, diverter valves, then the oil filter housing, and then TB. There are (3)-13mm bolts that hold the oil filter housing. Basically, the oil filter housing is removed for better access and view of the OEM plenum and hose clamps. Also, it makes it easier for reinstall of the IPD Plenum and the rubber boots. You wanna make sure you get the angle right, when you tighten everything back up, flat and straight, or else you'll get a misalignment between the TB and Y-pipe.
Todd told me the same, although the GT 30's may also benefit.
You rock....thanks!
Mackchacha
Jul 9, 2019 11:03 AM
PenguiN
Sep 15, 2015 11:44 AM
