Looking for GT2 suspension parts
Old Sep 10, 2008 | 11:44 AM
oak's Avatar
oak
ryan,
the factory GT2 plates aren't adjustable. if you don't have a set, check out the ones I purchased from AWE. I think there are subtle differences in the types of camber plates required not sure what exactly.
Old Sep 10, 2008 | 12:05 PM
oak's Avatar
oak
ryan, now looking at the diagram, it appears you can rotate the plates.
Old Sep 12, 2008 | 05:14 PM
itacud's Avatar
itacud is a jewel in the roughitacud is a jewel in the roughitacud is a jewel in the roughitacud is a jewel in the rough
Originally Posted by TXGold
According to Lex at Moton, the 996TT and GT2 C/O packages are identical except that Moton includes a sleeve for the GT2 suspension, due to the fact that it has different uprights(part that mounts to the wheel). Again, according to Lex, the stroke is the same.
As I mentioned before, new camber plates(the piece that goes in the top part of the front wheel well) and the associated hardware is not necessary. The GT2 strut will fit in the 996TT camber plate the same, except will be lacking camber adjustability the GT2 has.
So it looks like I need some locking rings and lower spring perches. Please contact me if you have any. The front lower spring inner diameter is 2 3/8ths.
Some have asked why waste your time, just buy some new Pss9/10's. I happen to have some GT2 C/O laying around and am just trying to make it work. I need to get rid of the stock strut and H&R lowering spring setup, and get something that doesn't handle like a turd in a punch bowl.
Thanks to all that have helped so far, and I hope this thread will serve as good info for the future.
Ryan in Tejas
BTW: Got a speeding ticket dismissed today. The Cop didn't show up!!!
The AWD's generally have longer front struts, than the 2WDs, since the front struts are angled backwards to clear the front wheel drive shaft. If switching to an adjustable mount, like the motons, etc, where the strut body can be moved up and down in the clamp, you just need the body to offer the extra length needed in the AWD install.
If comparing Moton front dampers for the GT-2 vs the 996, there isn't an intrinsic difference in the bodies supplied, but the GT-2 parts are usually built with droop limiters internally, that limit the total suspension extension. I say usually, since Moton will build pretty much any configuration you want.
The stock GT-2 damper body looks to be movable in the bottom clamp, so if it's long enough, it might be able to accommodate the higher mounting point needed on the TT. I think you'll need new front sway bar drop links as well, since the mounting point will be different on the new struts. Also, as Oak shows in those pictures, the AWD strut tops are angled differently, to accommodate the struts' driveshaft clearance. You might want to confirm the damper length and droop before buying too many parts! =)
Old Sep 13, 2008 | 05:43 AM
Mikelly's Avatar
Those look a lot like the MODE units I'm getting ready to install this weekend.
Mike
Originally Posted by oak
ryan,
Old Sep 13, 2008 | 05:32 PM
oak's Avatar
oak
mike, most everyone that sources these are made by the same mgfr. weltmeister.
Old Sep 14, 2008 | 08:47 PM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
Oak, your car is immaculate. I love it!
Old Sep 14, 2008 | 10:19 PM
oak's Avatar
oak
thanks ryan. hows the conversion going?
Old Sep 14, 2008 | 10:51 PM
TXGold's Avatar
Because of Ike I've had to put things on hold. I think it's down to locking rings spring perches and sway bar link holders for the front C/O's. Thanks for checking, Mad Power!
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
