MS 109 vs C16
Old Sep 12, 2008 | 03:46 PM
ttboost's Avatar
Originally Posted by robmd99
Yes, there seems to be a plethora of fuels.. from As to Qs LOL I am planning on running 2 bars more or less... so I am just trying to get a feel of what fuel I should use?
wow!! At 2 bars, that was what C16 is made for, but I seems many tuners think MS109 will be fine. IMO, if you wanna use C16, just DON'T let it sit for any extended period of time.
Old Sep 12, 2008 | 04:16 PM
Divexxtreme's Avatar
but is there a reason in your opinion?
C16 is far "safer" fuel. MS109 is only 105 octane compared to C16 which is 117 octane.
I personally prefer unleaded fuels over leaded, but at maximum boost levels...C16 or Torco 116 will definitely provide much greater protection than 105 octane MS109. It's pretty simple; the higher octane you run, the less chance you have of detonation occurring.
I'm almost 100% sure that if you try to run MS109 at 1.7 BAR or higher, you're anti-knock sensors will kick in....or worse.....
Old Sep 12, 2008 | 05:08 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Thanks Scott, now all I need is for Todd and Tym to give me there opinions...
Robert
Old Sep 12, 2008 | 05:11 PM
Robert
Rob,
Both Todd and Tym run and recommend running C16 for high boost applications...
Old Sep 12, 2008 | 05:18 PM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
I gave my opinion in the 2nd post of this thread....
While tuning on a load bearing dyno, I have been able to archive MBT timing on 109 with out detonation. This means I was able to run more ignition timing then would actually increase power with out knocking.....
C16 has his place, this I agree....in my opinion, there are very few cars in this community that will really benefit from it.
Old Sep 12, 2008 | 05:21 PM
robmd99's Avatar
Tony
I appreciate your knowledge and your opinion.... please keep giving it!
Robert
Old Sep 12, 2008 | 09:20 PM
robmd99's Avatar
Originally Posted by Divexxtreme
Rob,
Scott
Thanks for your response, I will ask Todd what he thinks I should do.
Robert
Old Sep 17, 2008 | 12:37 PM
robmd99's Avatar
Scott
How about plugs? Since it is so hard to change them as well as costly do you have to change them with high frequency?
Old Sep 17, 2008 | 02:32 PM
Scott
I haven't needed to change my plugs since I never run more than 2 tanks of leaded in a row. If I use leaded fuel, I switch back to unleaded after every 2 tanks of leaded to clean the plugs.
Old Sep 17, 2008 | 02:46 PM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
My car does not need that much octane..LOL..., but I ran Blown gas drag motors for years and nothing I ever tried was as good as C16, 9.25-1 static with 34-36 psi of boost, zero issues, a great fuel to be sure.
Old Sep 17, 2008 | 02:51 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Turbo engines LOVE the C16 - especially these 996TT purr like a kitten. With that said though, I always make sure to run at least a tank or two of unleaded through as soon as possible after using to clean things out. No harm done even with cats and O2 sensors.
Old Sep 17, 2008 | 02:59 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
Originally Posted by Tony@epl
In in most if not call cases I have been able to archive MBT before reaching detonation on both c16 and 109. This tells me that for most applications ms 109 is as good of a choose as c16.
I reserve c16 for very high boost, nitrous or VERY high horsepower stock motor applications.
For what its worth, my personal car runs over 2 bar of boost very regularly on ms 109.
Agreed proven on my evo same power was derived with no detonation.
S
Old Sep 17, 2008 | 03:08 PM
robmd99's Avatar
Thanks everyone for your imput, I will talk to Todd K about changing. Suman, any updates on your beast?
R
Old Sep 17, 2008 | 06:09 PM
ttboost's Avatar
EXACTLY!!!
Old Sep 17, 2008 | 06:52 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Can you mix C16 and MS109?
