Gen 1 PCCB rotor
Old Sep 12, 2008 | 12:25 PM
shadow996's Avatar
shadow996 is infamous around these parts
Gen 1 PCCB rotor
I just found that I got a chip on my front right rotor and it needs to be replaced. I really don't want to spend $5K+ just for one rotor from the dealership.
If anyone have one lying around, please pm me. Thanks in advance.
Old Sep 19, 2008 | 07:27 PM
mglamarche's Avatar
mglamarche is infamous around these parts
Replace PCCB with Steel Rotors
I have been through the same issue as you. I am currently working on the documentation of my process, with photos, for keeping my 6-piston calipers and swapping the worn out generation 1 ceramic rotors, to steel cup rotors with NO modification. I hope to have this completed soon and will post it. The local Porsche dealer wanted $4,100/ rotor with a core charge of $1,000 (this is for just ONE). For less than 20% of this cost, plus my old rotors, with hats, I had custom-made steel rotors made to exactly replace the ceramics. This was done on the front axle only. I am still using the ceramic rotors on the rear. Now I can use the very aggressive Pagid yellow pads at the track. The stopping performance is considerably better than OEM and there is no loud squeak. Call Cam at Maltby Motorsports in Woodinville, Wa. 425.481.1706.
Old Sep 19, 2008 | 11:04 PM
shadow996's Avatar
My dealer quoted me $5K+ for replacing one rotor, that's why I can looking for a used one. Going to steels are my last choice, as I don't want to change all 4s and dealing with more brake dust. thanks for the info anyway.. definitely an alternative
Old Sep 21, 2008 | 09:55 PM
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
I'm def. interested on how you fit the cup rotors w/o altering the offset on the hub/rotor assembly..,
Old Sep 21, 2008 | 10:37 PM
mglamarche's Avatar
With an EXACT copy made from your original ceramic rotor, using the SAME hats (with minor modification made to attaching hardware) there is NO need to modify anything on the car itself. The steel rotors weigh more, but I never noticed the 20lb difference and for the first time I have dust on my front wheels. The benefit is that I saved lots of green and can stop quicker than any ceramic set up with the more aggressive Pagid pads that can be used with the steel rotors rather than the wimpy pads that must be used for the ceramics rotors.
Michael
Old Sep 21, 2008 | 11:11 PM
petevb's Avatar
petevb is a splendid one to beholdpetevb is a splendid one to beholdpetevb is a splendid one to beholdpetevb is a splendid one to beholdpetevb is a splendid one to beholdpetevb is a splendid one to beholdpetevb is a splendid one to beholdpetevb is a splendid one to behold
Michael
My understanding is that the pad used for PCCBs is nearly identical to standard pagid yellows. Of course the rotor side of the friction surface is totally different, so it will perform differently, but I've been told those pads almost the same.
Racers do also switch pads on ceramics- pagid blacks are used, among others, though of course rotor life is affected...
Old Sep 21, 2008 | 11:36 PM
mglamarche's Avatar
Pads for Ceramic Rotors Vs. Steel rotors
I was not aware of this. I can say however, there is no comparison between the stopping power of the steel 350mm rotors with Pagid Yellow pads and keeping the original six piston calipers and the 350mm OEM ceramic rotors with the OEM pads. I stop far deeper into the turns and find no brake fade due to the heat build up (I’ve heated the rotors enough to see faint blue in them). The ONLY benefit I saw with the ceramic rotors was no brake dust...period. That's a lot of money for this feature!
Michael
ELMEL
Sep 28, 2015 01:12 PM
ECS Tuning - BMW
Sep 16, 2015 03:02 PM
spooltime
Cayenne Turbo
Sep 12, 2015 12:05 PM
Nuke
Sep 8, 2015 09:09 AM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
