Any performance upgrades for GT2's ?
Subscribe
Sep 17, 2008 | 09:28 AM
Quote: that would be ~550 HP with pump gas...
In the USA people get easily 600hp with stock K24's and a chip...Haven't you heard that before? Back in the day that was one of the first things I learned from this forum
Same tuners and their customers claim that stock 977 Turbo with stock VTG's and 600hp+++ is no problem at all...
Depending on dynos etc. this is true.
BUT good thing we know (at least I have experienced) how these perform in real life...The horsepower amounts are exaggareted. Now if some says that it's dyno-proven...is it on MAHA dyno or engine dyno and with pump gas...I doubt...
Ps. for the original poster: I recommend a small power increase like the guys above. But first go for a proper suspension like KW or similar. And a lot of tracking with the car, as you know, once going real fast with it, things might get dangerous...(and tracking the GT2 beast is best you can do with your pants on )
Reply
Sep 17, 2008 | 11:33 AM
Quote: heck with that work on the suspension!!!!! and you can drive the **** out if it just like it is!
but deffinate keep it around 600 hp if you want to drive easily and get power to the ground
Agreed on both accounts... Suspension was the best thing for this car, it makes all of the power usable and gives a new meaning to confidence while pushing the car near it's limits (well upper limits compared to Matt/930man LOL)
Congrats on the GT2, we should meet up sometime!
Reply
Sep 17, 2008 | 11:58 AM
it seems the horse they use for measurements are much different in size. I would love to have 600hp with just a flash. hahahah.... maybe not.
Reply
Sep 17, 2008 | 01:26 PM
Gt2
Depends on what you really want from the car. I'd agree with some of the other posters that you should invest more in optimizing the suspension setup for more GT3RS-like behavior. 600hp is plenty with these cars and is easily achieved. Some like a bit more(me included) but you can definitely go into overkill with power and lose the balance that make GT2's fantastic road and track cars. Significantly higher performance levels are certainly achievable but come with some compromise and can change the overall goodness of the car. That's why most suggest keeping mods to a minimum as the car is so right from the start with just very minor tweeks. You can't go wrong with a conservative approach.
Reply
Sep 17, 2008 | 02:23 PM
I hate how the euro market talks in crank HP while everyone else talks in WHEEL HP.
Reply
Sep 17, 2008 | 06:19 PM
Quote: Depends on what you really want from the car. I'd agree with some of the other posters that you should invest more in optimizing the suspension setup for more GT3RS-like behavior. 600hp is plenty with these cars and is easily achieved. Some like a bit more(me included) but you can definitely go into overkill with power and lose the balance that make GT2's fantastic road and track cars. Significantly higher performance levels are certainly achievable but come with some compromise and can change the overall goodness of the car. That's why most suggest keeping mods to a minimum as the car is so right from the start with just very minor tweeks. You can't go wrong with a conservative approach.
Thanks for all the info. I wasnt aware of all these mods but i will start with the basics, flashing the ecu & diverters. After that I will slowly make more additions as needed..
I will get some pictures up..
2003 Grey GT2 with carbon fiber rear wing, carbon steering wheel, carbon shifter & e-brake.
Reply
Sep 17, 2008 | 06:56 PM
make sure and get upgraded wategates as well.
Quote: Thanks for all the info. I wasnt aware of all these mods but i will start with the basics, flashing the ecu & diverters. After that I will slowly make more additions as needed..
Reply
Sep 17, 2008 | 08:07 PM
If you want to keep the car close to stock like I did, the only things I would do is have a good re-flash done on the computer, I had mine done by Prototech in Pompano Florida. I sent it to them and had it back in a couple of days, its easy to take out and just mail the whole thing to them. And I would put on a good set of waste gate actuators, I got mine from evo. I don't think you get much from the exhaust except a drone and I don't care what anyone tells you they all drone except stock. In my case I actually lost mph in the 1/4 mile with different exhaust. With just those couple of mods my car ran 10.83 at 130mph with drag radials and 11.1's with street tires in August and Sept heat.
Reply
Sep 17, 2008 | 08:53 PM
Quote: Another option is to dust the sand from your Vagina, install GT30's, fuel system, triple carbon clutch, exhaust and have the fastest all around car in your neighboorhood.
I have that now...Without the GT30s, just ask the Woodster aka 1 for 40. Although I do have some GT30s sitting here...Just waiting for a update from you.
Reply
Sep 17, 2008 | 09:37 PM
Quote: They would come out with these huge dyno numbers but when they got to the drag strip they decided it was best for them to leave all the horsepower they had back at the dyno because the cars would go nowhere at the drag strip.
Half of the battle is to get the HP and the other to put it to use.... both of which are not always easy to do at the same time...
Reply
Sep 17, 2008 | 10:05 PM
Quote: Half of the battle is to get the HP and the other to put it to use.... both of which are not always easy to do at the same time...
That is SO true..
Reply
Sep 18, 2008 | 03:20 AM
Quote: I hate how the euro market talks in crank HP while everyone else talks in WHEEL HP.
so US tuning Kits like EVO600 or 700 means WHP???
Reply
Sep 18, 2008 | 03:29 AM
Quote: If you want to keep the car close to stock like I did, the only things I would do is have a good re-flash done on the computer, I had mine done by Prototech in Pompano Florida. I sent it to them and had it back in a couple of days, its easy to take out and just mail the whole thing to them. And I would put on a good set of waste gate actuators, I got mine from evo. I don't think you get much from the exhaust except a drone and I don't care what anyone tells you they all drone except stock. In my case I actually lost mph in the 1/4 mile with different exhaust. With just those couple of mods my car ran 10.83 at 130mph with drag radials and 11.1's with street tires in August and Sept heat.
Jamie, are these sub 11s times done with race fuel? what boost do you drive?
Is the rest of your car stock or lighter?
Reply
Sep 18, 2008 | 04:37 AM
Quote: Jamie, are these sub 11s times done with race fuel? what boost do you drive?
Pump gas at 1.2 bar, the car is a little heavier than stock as it has a stainless Porsche roll bar.
Reply
Sep 18, 2008 | 06:08 AM
Quote: make sure and get upgraded wategates as well.
Yes ! Wastegates too.. Thanks !
Reply
