996TT Dyno question
Old Sep 17, 2008 | 08:55 PM
etzee's Avatar
etzee is infamous around these parts
996TT Dyno question
Need some help. Project needs a baseline TQ and HP of current mods on a 996TT EVO stg 2. On a Mustang Dyno-4 wheel dyno, do the front wheels spin? Do I need to disconnect the drive shaft before the run and dyno the rear wheels only? Car does not show any ABS or PCM error codes. Any help would be great. Thanks in advance.
Old Sep 18, 2008 | 07:34 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
If the dyno is a mustang 500se, like the one below. Make sure the shop locks the front rollers to the rear rollers, so they spin at the same rate...and you will be fine in AWD.
Old Sep 18, 2008 | 08:11 AM
etzee's Avatar
Thanks. I will check first. Do you know what the differentials are supposed to do? Do the front wheels not get driven until slip is detected in the rear? And if so, is 40% of the available torque available or less? This would explain why the front wheels don't spin if the dyno was not locked front to rear...maybe?
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
albert@velosdesignwerks
Ferrari
Aug 22, 2015 09:31 AM
