shift handle
Old Sep 25, 2008 | 01:44 PM
turbo turbo's Avatar
turbo turbo is infamous around these parts
shift handle
how do you remove the shift handle off an 04 6speed? THANKS..
Old Sep 25, 2008 | 01:51 PM
liquidcool's Avatar
liquidcool is infamous around these parts
Pry the plastic ring that meets the center console up with your fingernails or plastic pry tool. Then lift the boot up and you'll either be able to pull the handler right off the shifter, or you may need to spin it counterclockwise to get it separated. Takes no tools and about 30 seconds.
Old Sep 25, 2008 | 01:59 PM
mtesh73's Avatar
mtesh73 is infamous around these parts
i think there might be a small>>>
set screw or grub screw on the underside of the shifter **** itself that needs to be loosened. i believe it is a small allen head screw. if i recall correctly.
Old Sep 25, 2008 | 04:50 PM
wross996TT's Avatar
The set screw is only on certain types of shift *****...so if you have the standard shift ****, there is no set screw. It does take some force....it will release quickly...don't hit yourself in the face.
Old Sep 25, 2008 | 05:51 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
If it's the type that's just pressed on with a friction fitting, try rotating it as you pull upwards, but keep your teeth and nose out of the way when it lets go....a few guys have had to see their dentist after one of these sessions.
Old Sep 25, 2008 | 06:37 PM
mmmmm's Avatar
mmmmm is infamous around these parts
Open the sunroof and stand on the seats and wear a helmet.
Kai@ELITEMS
996 Turbo Vendor Classifieds
Nov 25, 2015 06:44 AM
Kai@ELITEMS
Nov 25, 2015 06:40 AM
Kai@ELITEMS
997 Turbo Vendor Classifieds
Nov 25, 2015 06:39 AM
ModBargains
Oct 13, 2015 03:40 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
