GT2 engine build help please
Hi guys after some advice please on getting the con rods and pistons connected after having the barrels off. Is there a special sequence to doing this,i've got 2 of them connected but now have found that i cant get them high enogh together in the barrel so i have got enough space to get in to connect the 3rd piston on the con rod,any help would be really appreciated,thanks in advance
Hi.... There is some tools needed for the install.......The #1 and #3 get the pistons installed in the sleeves and the #2 piston is installed on the rod with a piston ring tool. The #2 sleeve is removed from the jug.. It is a very hard job even for the pros. Good luck with the build... Here to assist, Tim
Here you go-
(Stephen (PorschePhd ^^above) from Imagine Auto)
http://www.imagineauto.com/996TTbuild.htm
Good pics and description of the tools.
Jul 29, 2019 11:13 AM
