Limits of the stock intake piping?
Tim,
I thought the X73 were motor mounts.
The picture is the transmission mount. I replaced mine as part of identifying excess driveline play. last year, I had to replace the transmission mounts (broken rubber), The front shaft (also the same type of broken rubber failure at the coupler) and the rear CV joints to tighten things back up.
I don't think a hole in the intake would cause a CEL, the larger problem is that it would suck in dusty air.
thanks sam
i like the FVD setup.. i know the aerospace flex tubing is very durable!
i also love the s-car-go stuff
tim
Years ago, when I first installed an early EVO GT640 kit on my car, I started off with the stock intake piping. I then added the V-Flow and FVD Intake Plenum. The combination of the 2 added pieces increased boost by 0.1 to 0.15 bar. Don't know if that helps you out at all.
Hitting the 1.3 bar throttle body shut down @ WOT in 6th almost threw me through the windshield. THAT was a serious reduction in power. If you're suggesting that having more pressure between the turbo's turbines and the throttle body, measured in the Y-Pipe, created less power, I'm not sure I follow your logic. There was no increase in resistance downstream of the pressure gauge. The V-Flow, theoretically, increases air flow upstream and the fatter tubing, after the turbos, allowed for more volume to the throttle body.
Jul 29, 2019 11:13 AM
Jun 10, 2017 07:45 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
