Roofliner squeaking
My headliner was rattling by the rear window. It would stop if you held the headliner down or grabbed the edge of it and pulled it down. What I did was take a small piece of papertowel and pushed it in between the roof and headliner with a small screwdriver. Problem solved!
I pushed it in from the back of the roof. THere is a gap between the rear window and the headliner that i pushed the folded paper towel under. It was a very small piece, maybe 1" long and .5" wide and .25" thick.
If you are squeaking in the front, i can't say what to do there since it would most likely get pushed out by the sunroof like you said above.
JSavinoJr
Sep 28, 2015 10:40 PM
