HELP!!! Need some technical advice > <
Just took my 2001 turbo to check PSM / ABS off issue, and got the error code 4205 (front left speed sensor wire) from PIWIS tester. We swap both front sensor between left and right and still got same error code at left side, thus, I think the sensor should be fine, next thing we do is remove some internal plastic cover and check each connecting joints and did not find any ware off joint or wire.
Does anyone experienced same issue or know the correct diagnosis procedure for this problem? Any input will be appreciated ^^
Oct 6, 2015 06:13 PM
