guys with 19" rims... what tire size are you running?
Old Oct 30, 2008 | 05:37 PM
DNugget991GT3's Avatar
im on a 235/315 set up
since ive gone RWD , i want to put a taller rear tire
i was thinking of going 325 30, but was wondering if it would rub against the fender...
Old Oct 30, 2008 | 06:33 PM
SamboTT@ByDesign's Avatar
Steve that (325/30) will rub. The 305/30's are usually larger than most 315's. It will effect your abs a tiny bit but help you with grip (contact patch) and gearing.
Try the suspension thing first. 235/315 should be fine.
Old Oct 31, 2008 | 12:29 AM
sam
i think my rear rim is 12" if not 12.5" BECAUSE, my 315 toyo tire has a streched sidewall
if i rolled the fender.. would i be set with a 325 30 ?
Old Oct 31, 2008 | 12:57 AM
Here is what I would do. First of all the Toyo is a little smaller than say a Michelin. I would measure the wheel and see in fact what size it is. It's most likely a 11.5-12.0. If you are like me you won't rest till you know. Maybe buy a set of 325's and try it. Worst case you can sell them but you will at least know.
Go to the tire manufacturer site and get measurements on the different tires. You will see different over all diameters, section widths and recommended rim widths. With this info you can see if it will work on the rim. As for the car you can roll like crazy and get another 1/4-3/8 inch. I know a lot of track guys including myself who run an 18x12 with a 335-30-18 Hoosier. I had to roll the fenders and use a 1/4 inch spacer to get the tire off the turbo to inter-cooler pipes. That is actually your biggest set-back which is why you need to roll and go outward.
FYI the Hoosier I got to work has the following measurements from Tirerack (top one):
http://www.tirerack.com/tires/Spec.j...e1=yes&place=2
This is a MPSC 325/30/19 (top one):
http://www.tirerack.com/tires/Spec.j...e1=yes&place=5
Old Oct 31, 2008 | 01:33 AM
RickEager's Avatar
RickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond repute
I have 2 sets of wheels. Both are running 315/25/19's on the rear with 235/35/19's front. Both are 8.5 fronts while my Champion's are 11.5 rear and my Zone's are 12 rear.
Old Oct 31, 2008 | 01:55 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
I'm running the exact same tire set up with Zone's. Car is lowered with PPS 10's with the rear fender lips rolled. No rubbing.
Old Oct 31, 2008 | 02:36 AM
Szpet's Avatar
Szpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud of
235/315 with 12.5 in the read
Old Oct 31, 2008 | 06:53 AM
damon@tirerack's Avatar
Moderator
235/315 for AWD safety.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Oct 31, 2008 | 07:02 AM
996twin_sc's Avatar
996twin_sc is infamous around these parts
235/315 here.
Old Oct 31, 2008 | 08:04 AM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
19x9 & 19x12....
235/315
Old Oct 31, 2008 | 09:07 AM
TAndujar's Avatar
TAndujar is infamous around these parts
I have Techart 19"wheels with Sport Conti 235 front and 325/25 rear in my GT2. I read your post about how your car feels. I do not feel comfortable with my GT2 over 170 mph. I have driven in my old RUF Turbo R (993TT based) at 207 mph on the Autobahn and in my RUF RCT Evo (964 based) at 205 mph on the Autobahn in Germany but the GT2 does not feel the same. I have spoken with people at Weissach about how the car feels and all of them suggest that I throw away the 19" wheels and put back the 18"wheels. BTW, I have driven a friend's GT2 with 18"wheels on the Autobahn at 200 mph and the car felt much better than my GT2.
Old Oct 31, 2008 | 09:24 AM
D_Nyholm's Avatar
D_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant future
Though it isn't wider, a 295-30-19 will work with minor rubbing at FULL compression. Mine only rubs in the left rear (my fat a$$ brings it down) and the tire is 26.1" tall which is a little over 1" taller than stock.
Old Oct 31, 2008 | 09:37 AM
jhuang25's Avatar
jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !
235/315 here as well... rolled my fenders on PSS9. no rubbing issues.
Old Oct 31, 2008 | 09:38 AM
jhuang25's Avatar
steve, on a second note, you're absolutely sure it's not a rim or an out of balance tire? do you get that same feeling when you're on your stock rims/tires?
Old Oct 31, 2008 | 11:04 AM
TAndujar that is very interesting...I believe it. It is hard to part with 19's.
Steve I did not even relize as I responded how huge that rear 325-30-19 would be. It will look like a hot rod! Or the Munsters car! Maybe stick with 315/25/19 or 305/30/19 (due to rwd) unless you go to 18".
