PROTOMOTIVE k24/20G'S ON AND RUNNING STRONG!
My K24/20 in action vs 997GT2
http://www.youtube.com/watch?v=Yy7yBMbxWU8
There was no Rain and boy we were pushing it hard , it was the final race for the championship here and who ever would win the race would be the champion. On the last lap he even pushed my car from the back to try to take me on the second to last curve (dont know if you can notice it on the video?)
Here is the whole race, he even started on top as I put too much at the start and got into a hard tire spin starting
There is the whole race:
http://www.youtube.com/watch?v=fiKw79Vb-8s
http://www.youtube.com/watch?v=8nPaMFfKiVQ
http://www.youtube.com/watch?v=8672VsdAutg
things r good waiting for some intercoolers from bell... and doing the fuel system next week
the car had a weird popping under WOT load fixed that last week (todd pulled a couple of degrees of timing)
injectors/pump/fpr?
sounds exciting. good luck to you!
siemens deka 60lb injectors
stock fpr
bosch motorsprts 044 piggyback fuel pump here is a link to the fuel pump setup i will be installing next week
http://picasaweb.google.com/carsandc...at=directlink#
tim
stock fpr
tim
I have the same setup but the bracket that holds them both is the OEM that used to hold the Fuel Filter and driving it keeps dropping , maybe too much weight (filter plus fuel pump), if anyone has come up with a solution to hold them in place please post images
Ya, I was going to say that sounds like your knock-sensors. Either pull timing, run less boost or higher octane fuel.
Looking forward to some 60-130 times.
What size Bell intercoolers are you going with and are they building it or are you going to put the core and end tanks together?
