What's the best way to remove a Clear Bra?
Old Dec 10, 2008 | 09:17 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
I need to remove a yellowing clear bra from a bumper that will be repainted. When I heat it with a heat gun and try to scrape it it melts. Any easier way?
Old Dec 10, 2008 | 09:25 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Use one of those garment steamer.
Old Dec 10, 2008 | 10:04 PM
TwnSpn's Avatar
TwnSpn is infamous around these parts
I use a heat gun at low heat and peel. If the bra has "crystalized" plastic razorblade or bondo spreader works best.
Old Dec 10, 2008 | 10:14 PM
adam699's Avatar
Thanks guys. I'll give it a try. When I try to peel it it rips and when i heat it it gets gooey.
Old Dec 10, 2008 | 10:44 PM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
I took mine off after leaving the car outside under the hot mid-day sun of Los Angeles in the summer time. I started with one corner and slowly peeled away. Came off nice and easy with no residue.
Maybe the heat gun is too hot. Maybe if you held a space heater to it...
Old Dec 11, 2008 | 08:41 AM
D_Nyholm's Avatar
D_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant future
I did the same thing as above. It just peeled off in one piece (the stuff is THICK). I had to use a decent amount of Goo Gone to get the glue off though. I had 3M installed on my car.
Old Dec 11, 2008 | 08:03 PM
HTP's Avatar
HTP
HTP is infamous around these parts
You are using WAY to much heat. It just takes a little. A hairdryer or steamer will work better for you.
PV=nRT.
Sep 9, 2022 06:06 PM
alevine
Nov 4, 2015 10:05 AM
MC36
Southeast
Sep 1, 2015 06:39 PM
SRC4S
Sep 1, 2015 09:22 AM
