No gas for the Turbo!!!
My friend called me today with a problem hes experiencing with his 03 turbo.. The car will not let him put any gas into the car! He says everytime he trys, the gas goes all over him. Didnt know if anyone knows why this is happening to his car?
Cole
Cole
There are a few possibilities, from a fuse to dropping the front suspension to get at the tank (as I recall). Search will be your friend:
https://www.6speedonline.com/forums/...archid=3667595
A
A
Happened to me, there is a electromechanical valve inside the filler neck- check fuses, I want to say E6 or C6 something like that, replacing the blown fuse fixed it. I'll do some searching and correct if I find it.
Yep: Found it, here: https://www.6speedonline.com/forums/...into-tank.html
Wross996tt wrote:
1. check the fuse (E6)
2. there is a valve in the fuel neck that sometimes fails (fuel bleeder valve)
3. there was an old TSB (TSB 5/99 2015) for fuel hose modification....but I don't think it effects your car.
It happened to me also, I kept going to different gas stations thinking it was the
filler hose. You can open that filler neck valve with a long straight object (like
a wooden dowel, or an aluminum driveway reflector stem).
Then fix the fuse.
MK
Then fix the fuse.
MK
