Help, lights won't turn on
Old Dec 19, 2008 | 06:25 PM
shaunt's Avatar
shaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud of
I'm not sure what's going on but I can't get my xenon lights to turn on. The fog lights and the small lights come on but not the main ones. Usually if I turn them off then on again they will come on but not tonight.
Help
Old Dec 19, 2008 | 07:06 PM
wross996TT's Avatar
First check fuses, then try jiggling your key in the ignition...my bet is the ignition switch.
Old Dec 19, 2008 | 07:48 PM
shaunt's Avatar
I tried jiggling the key in the ignition but no luck. Wouldn't a blown fuse effect all the headlights?
Old Dec 19, 2008 | 09:25 PM
wross996TT's Avatar
Are you kidding...there must be at least 8 different light fuses....did you check? What year is your car...I can post the fuse list...
Old Dec 20, 2008 | 10:09 AM
shaunt's Avatar
I checked the fuses and they are all good. After some more research I am thinking it might be the switch based on some other very similar situations.
Old Dec 20, 2008 | 03:39 PM
GT650-25's Avatar
GT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant future
I had the same problem...to fix it keep toggling the light swict on/off really quickly, it eventually comes on...its a hit or miss
You probably have a bad Switch, mine was replaced under warranty at 30K miles...
If no warranty, its a very easy and accessible to DIY part...Just buy the switch from Suncoast (sponsor on here, best prices) and then just ask any of us to run you through it or get a local race shop to dump it in, its like 1-1.5 HR labor
cadman
Nov 13, 2025 08:57 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
GSR Autosport
Aug 26, 2015 05:20 PM
DSCOFF
Aug 23, 2015 01:22 PM
Walorus
Aug 18, 2015 01:39 PM
