Driftbox won't pick up Sat signal
Old Jan 12, 2009 | 09:42 AM
Dr_jitsu's Avatar
It was nice and cold this morning so I thought I would get a sub 6 second run on my way to work.
Unfortunately the Driftbox won't get a satellite signal, it just keeps blinking.
I had the same problem this weekend when it was cloudy but today presented a crystal clear azure sky.
I also repositioned the box close to the midddle of my windshield but no avail.
Any insight?
Old Jan 12, 2009 | 09:49 AM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Sean,
You may need to let it recalibrate. I forgot how to do it, but when I borrowed the one you had it was having trouble also. I let it recalibrate and it started working within a few seconds.
Also when I get my headers and stuff on. I need to borrow it myself. I think with new plugs and 24psi it should really knock out a good time. My 7.4 was embarrassing but whats even more so now is when I got WOT it shoots a 2ft flame out the back of the car and it doesn't go anywhere. The plugs are THAT bad. So not only has it dropped me down that much power, it also has made it where I can't even go into boost. I guess after 5-6 tanks of C16 and the same set of Copper plugs I should have known what is going to happen. I didn't even run a tank of 93 between those, but oh well live and learn.
-Chris
Old Jan 12, 2009 | 09:51 AM
Dr_jitsu's Avatar
Do you mean push and hold in the reset button? I tried that several times.
Old Jan 12, 2009 | 09:54 AM
Powell's Avatar
Under the settings options there was a complete recalibration option. I forgot the actual name of it, but Ryan helped me figure it out.
Old Jan 12, 2009 | 12:14 PM
Szpet's Avatar
Szpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud of
They call it "Coldstart"
You should leave the car with Driftbox connected for 15 minutes in an open area, to re-acquire.
Press the MENU button from any display mode.
Highlight the setup option and press OK.
Select COLDSTART.
The following screen appears and a coldstart is performed.
Old Jan 12, 2009 | 12:55 PM
Dr_jitsu's Avatar
Thanks Szpet
Hybrid
Jun 28, 2024 06:05 AM
XLR82XS
Oct 5, 2015 07:02 AM
FUTURESTAR
Sep 23, 2015 05:42 PM
ECS Tuning - BMW
Sep 4, 2015 02:35 PM
MC36
Southeast
Sep 1, 2015 06:39 PM
