9.5" front wheel?
Old Jan 26, 2009 | 10:13 AM
BlueTT's Avatar
BlueTT has a spectacular aura aboutBlueTT has a spectacular aura aboutBlueTT has a spectacular aura about
9.5" front wheel?
Does anyone have a 9.5" wheel on the front. If so what is the offset you are running?
Old Jan 26, 2009 | 10:20 AM
WheelB's Avatar
Site Sponsor
WheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant future
18x9.5 i have run et 48 required a few minior body mods this was a track set up !
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest HRE Dealer In The World / Largest ANRKY Dealer / BBS Premium Dealer / TechArt Premium Dealer / Vorsteiner / Rotiform / Akrapovic / iPE / Novitec / Brabus / AC Schnitzer / Mansory / Brembo / RENNTech / Weistec / Tubi / Hamman / KW / H&R and tons more.
Old Jan 26, 2009 | 01:49 PM
Joe Weinstein's Avatar
I also run a 9.5" front wheel. I run a 265-35-18 tire and get some rubbing at
parking lot steering angles. I don't know the offset, but if you call Complete Custom
Wheels, they make them and know what offset to make.
Old Jan 26, 2009 | 01:58 PM
BlueTT's Avatar
Great thanks for the responses! I'm trying to get 18" track wheels. I currently have 19" wheels with 235's and 315's. I feel that the fronts just don't have enough grip, especially under heavy braking. I don't understand why so many are using this setup???
Old Jan 26, 2009 | 02:21 PM
Yes. CCW will make you good 9.5" fronts and 12" rears,
and 18'ers have many more better tire choices. But tires
and width aren't the whole story. You need 2-3 degrees
of negative camber to stick well in corners...
Old Jan 26, 2009 | 02:54 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
I also run a 9.5" front from CCW. They would know the offset---I don't. Have run Hoosier 275 R6 and Michelin slick 27/65. Need to roll fender wells and you'll get some rubbing on inner fender liners but nothing serious. May need adjustable camber plates to gain your neg camber at the top and keep the springs off the tires.
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
COBB Tuning
Nov 9, 2015 08:02 PM
ModBargains
Aug 20, 2015 12:28 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
